Look at the differences... The test conditions are different to reach the specs.2SA1943 is a 30MHz transistor in a TO-3P(L). MN1526 is a 60MHz transistor in a TO3P-3L package. They are different physical sizes - see data sheets. The SanKens could possibly oscillate.
How about..
Toshiba TTA1943 / TTC5200.
Thank you Karl and redk9258. The problem is that in India it is very difficult to get original 5200s and 1943s. But I have some original MN1526 & MP1526 transistors. That is the reason I thought about using them. Yes Sankens could oscillate.
How about..
TTA004B / TTC004B are 120V devices. Overkill, but their fT of 100MHz is closer to the originals' 150MHz.2SB1141 / 2SD1681
My attempt at finding an (available) sub led me to KSB772 / KSD882. Am I on the right track? Thanks ...
Since they are in a differential amp circuit it is good practice to match them (KSA992) for the same Vbe and, if possible, gain.sorry ,.. i have a question - i restore a KA7300
can i use for qe1 a ksc2383YTA and for qe2 KSC2690YTA ?
AllTransistors.com lists KSD560 as a suitable replacement.Am looking to replace a 2SC1983 in my Yamaha PF-800. This transistor is responsible for providing current to the arm lift solenoid, with 12V at its collector, upon 12V activating voltage to its base which is provided by an opamp.
It's a TO-220 package.
Previous suggestions are TIP112F or KSD1273Q, both of which are NLA. Any suggestions for a modern equivalent? Thanks in advance.
(Edit: MJE15032G has also been suggested in the past. Would this work?)
Note KSA733 needs "C" suffix for center collector - "KSA733C"!drop-in replacement for the 2SA733, the KSA733
They seem to be the original to me. Order some BC5566A earlier without knowing they are A733 actually instead. Wondering do I need to order KSA733C? What is better? And at the same time, since I have some KSA992 in hand, thinking about doing a quick swap on this pair to see can they fix my high DC issue. But even the readings on the original A733 seem pretty “matched”.Why not go back to the original BC556, or the drop-in replacement for the 2SA733, the KSA733. Both are available.
Question for me is if the 733's were a factory install or a repair. What's in the other channel?
But, yes, the KSA992 is a sub for the 733.
