Troubleshooting CD Players
I did remove the blob. Boy I cannot get that gear loose. Afraid to strip the head. Tried a PH00 and PH000, but can't seem to find a screwdriver to fit good enough where I can apply some torque. I'll retry the old. Thanks!!
Sometimes you have to use a jeweller's flat blade screwdriver. Some of these tiny screws are not Philips, they are a + screw.
I went to the New England Audio Fest today. In the free pile was a beat up Onkyo DX-703. So I took it. Looked it up when I got home and sure enough it uses a KSS-210A. So I put a cd in and it read it. So I put the laser in my DX-1800 and I'm back in business.
Obviously the Chinese laser from e-bay was crap. Please share the seller ID so no one else will waste money on it.
I found a reliable source for laser pickups! I had a customer with a SACD player with a bad pickup. I told him if he wanted to risk the money I would order a pickup and install it. I looked at e-bay for a KHM-230AAA pickup and looked at the seller's feedback and what else they sold. This seller, ameddio, has excellent feedback and guarantees everything they sell for a year. They specialize in electronic components for audio. The laser came sooner than expected, and works perfectly. I have been running it for about 3 hours and it plays every Cd I put in, including recordables. I can recommend ameddio as a reliable source. This is wonderful news!
A big thanks to dr*audio for this thread.
I had taken a punt and purchased a Yamaha CD-1050 (CDX-520) for $40 on Gumtree which was advertised as skipping.
I came across this thread before I picked it up. Once I received it, I played my oldest CD (Led Zeppelin Houses of the Holy), and sure enough, skipped here and there.
So, I cleaned the laser slide rails with Isopropyl Alcohol and q-tips, and re-lubed with a couple of drops of 3 in one oil. I added a couple of drops of 3 in one to the spindle motor upper bearing as well.
I also cleaned the upper clamp ball bearing with Isopropyl and re greased with a dab of normal grease, as oil would run everywhere.
Now it works flawlessly, no skipping on 3 play throughs. The player sounds great and plays burnt CD's as well. I bought the player for my Uni Student daughter, and she's going to love it.
She probably has 50 CD's, but no CD player. Listens to her music on Spotify, go figure.
Has anybody seen the bridge ? Where's that confounded bridge ?
Mr Relish
@MonkeyRelish First, WELCOME TO AUDIOKARMA!!!
Also, I think I remember Dr*audio being a bit unwilling to recommend 3 in 1, for some reason. I may be wrong. Anyway, happy listening, and my own cd I've had the longest out of the 2500 or so I have is ALSO Houses of The Holy.
Great minds think alike, lol.
Yeah, 3 in One gets gummed up after awhile. TriFlow is great stuff. If you can't find that, look for DuPont Oil with Teflon, or a light machine oil that is not 3 in One.
That would be right. I went to Bunnings (Our version of Home Depot) to look for the triflow, or light engine oil. I could only find WD40 and CRC, both not really appropriate. There was 3 in 1 or another light oil. I hummed and haaed for a couple of minutes, and settled on the 3 in 1. There were no Teflon based lubricants. Still it worked, and if the CD player starts skipping again, I know what to do.
Thanks again dr*audio.
I posted in the Kenwood section, but I'll repost here as it may yield further results-
I have a Kenwood DP-750 that has a distortion problem- on both the fixed RCA outputs and also the headphone output (Has a volume control). I cleaned the lens and fixed a cracked solder joint on the RCA connector on the rear, but otherwise it's in great shape. When a disc is inserted, it quickly reads it and moving between tracks is very fast. However, I get distortion, mainly on loud passages. Most of the time it's a "shimmering" type sound, other times it's a quiet clicking or popping. Some discs are definitely worse than others. Seems like "louder" discs are worse, but almost all my discs exhibit some type of distortion. Using headphones and turning the volume down helps with the breaking up of treble, but that hissy "shimmering" still exists, as does some distortion. The clicking/popping seems to be at random, not necessarily during loud passages. It does not seem to coincide with scratches or blemishes on the disc either. So the question is- Is this normal operation for an old (November, 1986) CD player, or are there things I can/need to do to correct this? I have a service manual on the way from "that auction site." If I should make this a standalone thread, I can do so too.
Usually this is caused by a bad DSP IC, but it can also be caused by low laser power causing excessive bit errors. The DSP IC is a flatpack surface mount IC with usually 100 pins or so. Not something the average person can resolder, if you can even get the part.
Unfortunately, that's what I figured. I had taken a look for other bad solder joints, especially around the chips, but didn't find any. So I'm guessing this poor deck is on its way out slowly. I'll use it until it dies or use it as a backup. I think it had a rough, long life. It still looks great, but I have the feeling it has some serious hours of use on it. I have a manual on the way for it. I'll read over it and, if there's an adjustment, at least turn down the output level a little bit to control the treble breakup.
If you have an oscilloscope, look at the rf waveform. It should be 1.2V P-P to 1.5V P-P. If not, the laser power is low. There may be a small trim pot on the laser pickup to adjust this. Just turn a little at a time.
