Troubleshooting CD Players
Will do, dr!!
What I have learned is that this JVC 1050ZL or whatever the number is, is NOT very good with dealing with damaged/scratched discs. It will read an unscratched burned disc just fine.
So, I placed a single, gossamer drop of oil at the top of the shaft of the motor moving the disc. Let it slide down and soak in.
Aside from it going bonkers on a heavily damaged, but buffed copy of "Vanilla Sky" soundtrack, it's worked pretty perfectly since then. I suspect something else is at play. It'll play an entire cd without an issue (and usually prefers being on awhile) but then out of nowhere, it'll start assing up. But, that's been nearly eliminated with the oiling.
THANK YOU @dr*audio for this most excellent thread.
Dear Dr!
I have a Denon DCD-1450AR cd player. I got it from a guy for free who told me, it doesn't read any disc. The tray moves freely, and the pick up starts to search focus, it moves up and down and sideways to, but nothing happens. I bought a new pickup from a guy on ebay (it seemed to me he doesn't sell a lot of pickup, he got got just one, so i though he he tell to truth when he tell it is working.). Until it arrived to me, i read a lot about that cd player, and i found that in a service manual, that it has a built in automatic servo adjustment system. When the pickup i ordered arrived, i replaced the old one, and than started to adjusment the new one with the automatic software. When it finished, i turned off, and on the cd player, and i was suprised, it read cds without any problem. I was curious, and i put back in the old pickup, runned the software, and it also worked fine. I was very happy!
I turned off for a night, and in the morning, unfortunately it didn't play anything again. I runned the adjusment software again, and after then it worked well again. I realised that, after an automatic adjustment, it will work well, until i turn off the cd player. If i turn off, and turn on after 5 minutes, it can read the cd, but only for the second, or third try. And after 10 minutes, it does not work again. After an autimatic adjusment i read out of the memory the value of FG, FBal, FOFS, TG, TBal, TOFS (i don't understand what are they mean), and all of the values are in the normal range, wich are specified in the service manual. But it is like the player forget the adjusments after i turn off that.
What you think? What is the problem with that cd player. It is a dying laser, or other electric problem? Do you have any tips about the solution? It is a bad servo chip? Or a dried up capacitor?
Thank you for your help!
Regards,
Tamás
Okay, so after firing it up over the weekend, the skipping (almost ALWAYS forward) happened again. I tried rewinding, and it just wasn't happening. It STILL skipped forward.
So, I left it on all weekend. Played flawlessly.
Maybe another single drop of oil on the shaft of the main motor??? I gave way too much for this old machine, mods and all, but it sure sounds great when working.
Dear Dr!
Regards,
Tamás
Likely a capacitor used to store energy (like a battery) needs to be replaced. The unit likely uses this to store the calibration settings for the calibration in memory.
So, if you leave it on continuously it seems to fair better than from a cold start?
Yep. I am leaning towards leaving it on indefinitely. Some say that the trauma from on/off cycles is more destructive than just leaving it on.
I know nothing, but it reads CD-R's without fail as long as its been on awhile.
Thank you! Last week i did some experimentals and I noticed, that if i left the cd player off for a night, than when i turn on at the morning, it doesn't read any disc, but is i wait for example 5 minutes, it can read anything. It is pretty interesting...
Maybe it has an auto-calibrate function if it detects the calibration settings have been lost in memory?
Denon dcd 820, low output on rca jacks but seemingly normal volume on headphone jack. I am guessing this is not a laser pickup issue. What should I be looking at?
I found a service manual on hifiengine but it's in German, English would be nice. :)
I picked this up for $5 at a rummage sale this past weekend with no remote but, I have a dcd 920 of the same vintage and it has to sets of rca outputs, fixed and variable.
Tried the 920 remote, which is the same remote, I believe, and no go. Wouldn't you know it? Dead batteries. Bah! Fresh set of AAs and it works, ran up the volume and everything is good. The 820 only has a single set of RCAs and it is the variable variety.
Thanks for the recommendation.
@dr*audio I've read the whole thread.
I have a NEC CD-730 that I was excited to get and appeared to work fine when I tested it. The player will recognize the disc, load and play tracks fine and all the buttons work and the time and number of tracks is correct... all the buttons work....
HOWEVER, there is NO SOUND OUTPUT for the headphone out, or either of the two outputs (fixed and variable).
The only thing I have tried was to leave it powered on for a full 24 hrs to see if it would get any sound output.
Looking for anything I can try to get output out of this cd player -- Thanks!
Ideally you need an oscilloscope to troubleshoot this, to see if there is audio coming out of the DAC, through the filters and the buffer amps. If you don't have a scope, but you have a meter you can get the schematic and see if there are muting transistors on the output, then check them to see if they are shorted, and check the power supplies. With no scope that's all you can do.
While I am technically challenged, I appreciate this thread and the help from dr*audio and others who are contributing. I have an old NAD 542 CD player that was displaying the toc but not playing and then went to the no disc reading. I have an oscilloscope hidden away but have not used one in about 45 years (most of my career was spent in a non-technical field). I could not see the laser light with the old laser pick up and did replace the pick up (ksm213ccm) which was cheap enough. I removed the solder blob and don’t think that I hurt the new pick up. I still can’t see the laser light. The good news is that I didn’t lose any parts or destroy any connections to the best of my limited knowledge. Anyway, I still get a no disc reading. The tray opens and closes appropriately and the pick up tray goes up and down. The motor that is part of the pick up assembly on the new pick up rotates but cannot get the disc to spin while it is rotating either with the upper cover that has a passively rotating disc on or off. I would appreciate any suggestions. I can see having damaged the new pick up or having made a mistake in engaging the plastic tray that the pick up assembly is attached to so that the gear (more like a groove) on the drawer mechanism doesn’t move the pick up tray into proper position but cannot understand why the spindle appears to be in proper position under the cd, rotates (it appears to be in one direction then the other) without rotating the cd disc. Thanks.
Marc
Marc
It sounds like the mechanism either isn't rising up all the way to play position or you put something back together wrong. Use your powers of observation. the CD should be sitting on the disc table. Maybe the disc table got loose and dropped down. Don't mess with the disc table until we make sure everything else is ok. Take some high resolution pictures, with a real camera, not a cell phone, with the camera on Macro and in focus, then upload them to a picture hosting site like imgur, and post a link here. Take pictures of the mech with the drawer open, then closed with no CD in the player.
Thank you sir. It will be a while until I can get to the picture posting stage but you inspired me to fiddle some more and the problem is definitely related to the mechanism that causes the rising and falling of the laser pick up assembly tray and the contact that the motor assembly pulley, which is part of that tray, makes with the disc in the disc drawer tray.
It appears that there only a few things that I can adjust. There is a cylindrical projection from the plastic laser assembly tray that fits into a spiral groove that is part of the open and close mechanism of the disc tray (belt driven) which moves the laser assembly up and down and is, in part, responsible for positioning this tray so that the pulley makes contact with the cd in the tray. The laser assembly includes the motor which rotates the disc and is mounted on a plastic tray to support it. On its underside there are 4 screws which pass through springs which can be tightened to various degrees adjusting the spring compression and, I believe, the pressure the pulley exerts in the cd disc.
I either have made a mistake in placing the cylindrical projection in the groove (which seems unlikely but possible since opening and closing seems to function appropriately) or (I think) more likely, it is a matter of adjusting the 4 spring bearing screws which is maddening since, there are 4 screws to adjust and I have to remove the 2 screws that hold the pulley on the bridge that goes over the cd tray and remove the 2 screws that cover the plastic rods on the far side of the plastic laser assembly tray (the rods allow the assembly tray to rotate up and down when the assembly is raised and lowered) so that I can lift laser assembly off its tray to get to the 4 springed screws underneath. I guess that this will involve trial and error.
I will report back when I can, which won’t be for a few days.
Marc
Marc
Do NOT adjust the screws on the springs. They go into plastic bosses and are meant to be tightened until they just stop turning, or you'll strip the bosses. The screws should not be loose, however. The springs are not all the same. There are springs with more tension that go near the motors. If you took them off and mixed them up, the mech could be sagging where the motors are.
I doubt the drawer / lift timing is messed up or the drawer wouldn't work properly. The belt could be slipping and the mech won't rise all the way. That is very common. If the motor that raises the mech is still turning when the mech is up as far as it will go, the belt is bad.
Thanks again. Great information. I may well have exchanged the springs and will look at the belt. I will need to let this sit for a while but will report back when (if?) I get this straightened out. Meanwhile let this serve as a lesson to others not to do as I have done and shun those screws on the laser assembly tray that make it go up and down.
Marc
