Troubleshooting CD Players
Hi, Yamaha CDX-1030 from post 231 is fixed.
I ended up replacing the four 2SB1185's and 2SD1985's. I also replaced the 7805 voltage reg while in there. I have put through about a dozen albums so far and touch wood no skipping at all. Before it would have skipped after 1-2 hours of use.
Thank you to dr*audio for taking the time out to help everyone on here with their usually old but very well built CD players.
I have good news! I have found a reliable source for laser pickups. Liberty Electronics on e-bay has a lot of laser pickups. I had ordered ICs from them before and they were good, and they have good feedback so I decided to try them out for a KSS240A laser pickup. It worked perfectly. I put it in a customer's Musical Fidelity X-Ray player. I listened to it for 2 hours. If it dies in a month I'll report back here, but so far it's great.
Great, I will have to see if they have the upside down Pioneer lasers because I have a beautiful TOTL changer that won't reliably read.
This is indeed fine news, Doc. My JVC xL-z1050 has so far proven to be a really difficult devil to figure out. Last night, it did the jumping forward thing on 3 different discs, only to play 2 other discs all the way through without a single hiccup. Completely and totally random when it will happen. I have to think, with the long load time, and the jumping forward, that the laser might be dying, or maybe when you advised me to oil the motor, that I didn't actually get oil to it. Has bested me so far, but when she works, man, she's a sweet one.
Do you have an exact seller ID? I'm searching and can't find that seller. Thanks! (I'm looking for a PWY 1009 so they probably don't have one anyway but it's worth a try.)
Thanks. No luck though. Last week I picked up a used PD-M400 CDP off Marketplace and it worked fine when I tested it. Put the laser in my PD-M910 and it doesn't even recognize a disc. @#$%@#$%@#$!!!! Dropped the whole pile off to tech this morning; if he can't get it working the whole pile may be scrapped, beautiful though the 910 is.
Hi, It could be the little rubber mounting grommets for the laser assembly that have sagged, this can cause issues on these Pioneer multi disc players.
You may be right, I did notice they looked a little sagged, but how was it working in the PD-M400 then? I'm just going to let the guy with better tools and knowledge play with it as he's already been twiddling inside this unit before. Got it with a laser with missing lens, successfully swapped in another laser from a crap unit and it worked for a while, then started mistracking, he said he couldn't get it to hold adjustment and I needed yet another laser, oddly after he messed with it it worked fine for another year or so then started mistracking again on tracks 3+ on average CD. I just dropped the unit off with all the Pioneer parts I had and said either make it work or I'm done with this unit :(
Maybe it just sits a fraction higher in the PD-M400 for some reason, it doesn't take much. It may not be the issue but was just a thought. I have one here that l ended up using very thin fibre washers under the rubber grommets and now works fine. There was someone on the bay selling the proper rubber grommets at some stage but l can't fine them now.
Fair enough, l hope he can get it sorted for you.
Hello to all! Long time mostly lurker and occasional poster. I have a Yaqin SD32-A CD deck purchased in 2012 - based on reviews I read here. I rolled out the stock tubes of the tube output stage for some nice Psvane tubes and absolutely love the sound. Last year I accidentally turned it off with the remote when a disc was still playing. After that it would not play the CD (still stuck in there) and the front loading door would not open. We lice in Raleigh NC, were new here at thew time, and I went to a shop that charged me about $150 to "repair" the unit. He provided no details about what he did. Earlier this week I tried to eject a disc that was in the unit (same disc had previously been played and removed with no issues.) This time the door would not open but the disc that was in there still plays. Tried both the eject button on top of unit and the one on remote - no luck. I viewed a couple of videos on changing the belt of a DVD drive and hoped this would be as easy (granted - there could be some other issue.) The cover is secured with Allen screw and came off easily. The rectangular piece of plastic with the semicircle on one edge (holds the CD down to the chuck?) is secured by two tiny Phillips head screws - also easily removed. Here is the issue: I can't see a belt and can't gain access to the CD mechanism underneath. There are plastic tabs on both sides of the black plastic assembly which *appears* to hold the CD mechanism. I can get the whole assembly unlatched at the far end (away from front of drawer) and on the sides, but it is still stuck at the front. Furthermore... now that I decided to wait until I have better intel, the drawer protrudes about 1/4" - no closes all the way but still will not open.
What to do? based on previous reading (years ago) I recall that the CD mechanism is a Sanyo component. Not able to ID the part # but Sanyo mechanisms are $8 and under on eBay. I emailed Yaqin, requesting the Sanyo part # and/or verification of who made the part, but not holding my breath on a reply form them. The original eBay seller form whom I purchased the deck *might* know, but his seller name was Song (based in Toronto area) and he appears to no longer be listed as a seller. I don't mind spending another $100 to $150 to have a shop resolved this but I want it actually resolved this time - not just fixed short term.
cd-01.jpg cd-02.jpg cd-03.jpg All ideas, comments and feedback gratefully welcomed!
Dr - I have a Esoteric P-10 and have replaced both belts so the tray and disc lift works. Big issue, however is that it is skipping badly. There is not a lot of info on the web for this model and I would very much like to have this working as it is built like a tank and is a desirable Teac VRSD unit. Always skips on track 1 around 46 sec in and skips all over..
Take some high res pictures of the mechanism with the drawer open and I'll see if I recognize the mechanism, then I'll know what could be the problem. Make sure they're in focus. Upload to a picture hosting site and post links.
What to do? based on previous reading (years ago) I recall that the CD mechanism is a Sanyo component. All ideas, comments and feedback gratefully welcomed!
Looking at your pictures, the mech looks like a sanyo sf P101N. that said, the symptoms you describe seem to point somewhere other than the mech itself - a tired drawer belt? cracker gears?
Here some pics of the Esoteric P10 with the tray open. I really appreciate your help on this. It is such a solid machine that I hate to throw it out.
It sounds like a bad loading belt. The shop probably put in a crappy replacement or a thinner one than the original. Many of the belts available today are junk made in China and don't last long.
This is why I don't like to work on mechanical devices anymore. If the reliable sources I use do not have the rubber parts, I don't accept the job.
You have to remove the mech to get to the belt. If the lousy shop you took it to can do it, so can you. You may have to remove the drawer first. Try to gently pull it out by hand. If it won't move, there may be an access hole on the bottom panel where you can insert a screwdriver to turn the cam gear and move the drawer out. If you get it to move, pull the drawer out all the way, then push it back in slowly. Most players have a spot on the drawer or cam gear with no teeth, so that after the drawer goes in, the cam can still turn and raise the mechanism to play. When you push the drawer in, it should now come out freely. If it is held up at the end of it's travel, look for a locking pin that prevents it from coming out. Sometimes there is a screw, sometimes a pin, sometimes a flat, springy piece of plastic that has to be pushed aside.
When you get the drawer out you should be able to see the screws that hold the mech, or you may be able to get to the belt. I haven't worked on a Sanyo mech since 1998.
View attachment 1679256 View attachment 1679257 View attachment 1679258 All ideas, comments and feedback gratefully welcomed!
I can't see enough of the mechanism, but at this point I have good news and bad news. The good news is that you have a Sony laser. The bad news is that laser is no longer available so when it goes belly up you have a boat anchor.
For skipping the first two things to do are:
1. Oil the top bearing of the disc motor. I think you will have to remove that big aluminum clamp support to get to it. Use a light machine oil.
2. The laser moves back and forth on 2 machined posts. Clean them with alcohol, allow to dry and put a couple drops of light machine oil on the posts on both sides of the pickup. If this has a linear motor to drive the laser, rather than gears, move the laser back and forth to spread the alcohol and then the oil.
Would you recommend using something like a sewing machine oil? I think I would need something like a syringe with a needle to get to the bearing on the disc motor.
