Troubleshooting CD Players
So this seems as good a place as any to post this info. I picked up a 1996 Technics SL-MC50 60+1 Cd Changer on FB marketplace yesterday. The guy had it listed for $40, but offered it at $25 because he lost the remote. I went to pick it up, and found the transverse movement DOA. He gave it to me for nothing, and I took it home to find that it had a stretched old belt. $9.99 plus postage on Ebay for 2, but based on some info posted in an Ebay review of the SL-MC50, I picked up a 15/16ODx1/16 diameter O-ring to try, for under a buck from an auto parts store. 10minutes after I got home with the o-ring today, it was working like a charm. This also replaces the belt in the SL-MC310, SL-MC70, SL-MC60, SL-MC59, SL-MC7, SL-MC6, SL-MC4, SL-MC3
Do it on the cheap. ;)
O rings can work to replace a belt but are usually a harder durometer rubber and get stretched out. They are designed to be compressed, not stretched.
Thanks
I was thinking that might happen in the future. Now that I know it actually works, I'll likely order the real belt. I was trying to avoid throwing good money after bad!
My Technics SL-P520 CD player has started getting picky on what CD's it wants to play.
Some play perfectly, but some will spin then stop and will not show the tracks. All the CD's are originals, that played perfectly in the past.
Any ideas? Would love to save this gem!
Weakened laser? Spindle motor needing lube?
Clean the posts the laser slides on with alcohol. Allow to dry and put a couple drops of Tri-Flow on the posts on either side of the laser. Lubricate the top bearing of the disc motor with light machine oil.
Hello,
I am new to this forum but I found it of incredible benefit as soon as I first read it. I have a problem with a CD player that is giving me headaches since a month, so I'd appreciate any help. Here it is.
Most of times, the player freezes after closing the cd tray. No track's list or number appears on the display, which suggests the TOC is not read.
In some very rare occasions, though, the player manages reading the TOC and plays the first track correctly, which suggests that the laser is working. The latter was confirmed once I opened the tray and switched on the laser with the help of a voltage source (don't look at the laser!) to check for the light. I cleaned the lens but this did not solve the problem, so I start checking the signals on the connector from the cd-tray to the micro-controller and figured out that the problem may be linked to the leaf switch which tells the micro controller that the player is homed.
If the player sledge reaches the leaf switch, most of the time the switch is kept closed, the lens does not go up and down, and the player freezes.
On the other hand, something different happened when I manually triggered the leaf switch with a screwdriver's tip while the sledge was moving to the home position. In this case, when I poked the leaf switch with the screwdriver and immediately released it, the sledge halts and the lens moves up and down, i.e. the focus routine takes place. In other words, the focus routine takes place if the leaf switch closes and opens again. I think this was mentioned in the very first post in this forum, but I'd like to know a bit more.
My questions:
1) can somebody confirm that indeed the leaf switch must be opened again once the sledge has reached the home position and closed it?
2) If so, I presume it is the micro controller who tells the sledge to retrieve, right? Any idea on why this does not seem to happen most of the time on my player? Could it be the belt driving the sledge motor, which although looking fine, maybe wear out and does not have enough grip?
Could it be the sledge motor? Or maybe the leaf switch to be replaced?
At the moment, I am waiting for new leaf switches to try, but all I could find is some cheap stuff on Amazon... so I am not sure this will work.
Confirming the analysis above and maybe some hint would be highly appreciated.
Thanks for your help!
Good troubleshooting! The correct sequence of events is:
1. Drawer closes.
2. Micro commands the sled motor to go to home position.
3. Sled causes home switch to close, sending a signal to the micro.
4. Micro commands the sled motor to move away from the home position.
5. Home switch opens, sending signal to micro.
6. Micro commands sled motor to move to TOC area, TOC is read.
Clean the home switch. It is either not closing completely or the switch is making a noisy signal.
Hello,
My questions:
Hello.
Thank you very much for your reply and confirmation. I did not reply before as I wanted to try first the new leaf switched I just received. Unfortunately, the replacement of the old leaf switch with a brand new one did not solve the problem: once the sled hits the switch it stops --> no focus routine.
I connected an oscilloscope to the wire (serial bus) the micro controller (LC6554H) uses to talk to the servo driver chip (YM7121C) and observed these two scenarios.
a) (no focus routine): while the sled moves to home position, and EVEN AFTER hitting the leaf switch, the micro-controller keeps sending the same 8-bits to the servo-driver. Looking at the data sheet, these bits corresponds to the command "forward".
The IC (LA6510) driving the sled's motor gets crazy hot if I keep the player in this state. It thus seems the micro-controller keeps telling the servo to advance the sled, without acknowledging the switch has closed. The sled's motor driver thus keeps pulling current and gets hot. Yet, the sled and the cd-tray move forward and back without troubles so the IC is not broken.
b) (focus routine): When I poke the leaf switch with a screwdriver, so that it closes and opens, the sled initiates the focus routine at the point where it stopped. In this case, after I poke the switch the micro toggles from the "forward" command to another one and then mutes while the focus routine takes place.
Not sure if the above triggers some ideas. It seems to me that either I need a leaf switch which toggles (close and then open), or that the micro has a logic error, which seems very unlikely as the player works from time to time, although rarely.
Do you have any suggestion or check you'd like me to try?
Last but not least, when connecting the oscilloscope to the bus, I am not able to capture the 8-bit command: "micro tells the sled to retract (point 4 in your list). That's why I actually asked to confirm the exact sequence of event, and you did it perfectly! Maybe the command lasts only few milliseconds, so the trigger misses it, but maybe there is something else preventing the micro to send out this command, or maybe the sled's motor does not react that quickly.
...In any case, I am not going to give up on this :-).
Not sure this is relevant, but the few rare times this cd-player is working (like right now, it can produce sound) is when it starts with an already-inserted cd and an already-closed tray. The other times I load a cd by opening and closing the tray, the sled blocks once it pokes the leaf switch. When working, if I deliberately stop it, open and close the tray without touching anything else, then it blocks as the sled touches the switch and that's it: game over aaargh! ...It is as if the CD player 'runs out of steam' if it goes through the whole loading process.
Maybe the sled's motor is wear and offers too much friction for reversing the sled's direction once the switch is touched... when monitoring the voltage rail of the sled's IC driver, I see they drop of 1V maybe 2 when the sled is moving, before going back to normal (16V or so). Could this be a sing of a leaky cap? it's speculative, but it feels like I am out of options.
It is possible the micro is waiting for something else to happen. Maybe the drawer close switch isn't working, or maybe there is a switch that senses the mechanism has risen up to the play position. Check those. Check the micro power supply with a scope. If you see more that 100mV ripple on it, replace the filter caps.
Hello guys. I’m not sure I’m at the right place for this question, but I’ll shoot it anyway. I have a arcam bdp100 which is stocked on the « hello menu » I guess I could say, In standby mode. I’m wondering if there’s a way to bypass or repair this, and if not, can I take out the transport and maybe use it in some ways ?
thanks
Fred
thanks
Fred
If none of the buttons work at all, first make sure that none are stuck in. A stuck button could cause this.
If not, get a service manual and check the voltages. If you have an oscilloscope, check the supply for the microprocessor. It should be 5V or 3V. If there is ripple on the supply, replace the filter caps.
If all this sounds like Greek to you, take it to a qualified tech.
Dr. Audio, thank you for starting this thread and sharing your technical knowledge and skill. I've followed this DIY for a few years and it's helped me keep a few old Onkyo Integra decks going. I've got another Onkyo DX-C540 6 disk changer (circa 1998) I would like to ask your advice about. I think I know the problem, but might be missing something so I'm coming here. I have a copy of the service manual.
Issue: Drawer will not open or close using the open/close button on the display panel. It works fine with a remote. I've DeOxited the button switch for the open/close button, but that didn't help. The open/close button is on the display circuit board (U2). The display works perfectly, as do all other button switches on the display circuit board. At this point, I'm assuming the button switch is bad (the problem) or possibly the capacitor (C701) above that is /connected to that switch.
Questions:
1) Is there anything else I can check?
2) What might the capacitor do?
3) Have you seen this happen with Onkyo units you have worked on?
Potential solutions:
1) Continue to use remote and forget ever using the open/close button on the display panel.
2) Find a suitable donor unit and change out the display circuit board.
3) Find a button switch and/or capacitor and change them out.
4) Other, based on your expertise.
Once again, thanks for all of the advice you have shared in this thread. It's been an equipment saver.
Questions:
Solder a couple of wires across the switch and, with the power off, connect them to a meter on Ohms. Push the switch and see if it reads close to 0. If it reads open the switch is bad. There are 4 pins on the switch. 2 are shorted together on each side, so if you read a short with the button not pressed, try the 2 pins on the side 90 degrees from that side. If you have an old junk vcr you can steal a switch from that. Digikey has switches, too.
Thank you for responding and your advice.
After my original posting on Monday, I purchased a used display unit from an Onkyo DX-C340. Not the same display unit as my DX-C540, but it has 19 of the same button switches that I suspect is my problem. These switches are all two pin. I removed one from the donor display unit and soldered it into my original display unit circuit board. After a little clean-up and screwing everything back together, I can confirm that the CD player drawer now opens with the open/close button, and with the remote. All other button switches continue to work properly, so the unit functions as new.
Once again, thanks for all of your advice since the start of this DIY thread. I've learned so much following it!
Dr. Audio, What a great thing you are doing here. Hoping my beloved Pioneer P-D70 vintage player hasn't bit the dust. When I put a disk in, the tray closes, the disk spins up and I can see the laser bob up and down. Then the disk stops and the tray opens. There are two micro switches that are tripped when the tray closes, and I've tried electric contact cleaner on them. Did not help. Do you think this player is worth saving?
Does it read the table of contents?
