Troubleshooting CD Players
I can't see enough of the mechanism, but at this point I have good news and bad news. The good news is that you have a Sony laser. The bad news is that laser is no longer available so when it goes belly up you have a boat anchor.
For skipping the first two things to do are:
1. Oil the top bearing of the disc motor. I think you will have to remove that big aluminum clamp support to get to it. Use a light machine oil.
2. The laser moves back and forth on 2 machined posts. Clean them with alcohol, allow to dry and put a couple drops of light machine oil on the posts on both sides of the pickup. If this has a linear motor to drive the laser, rather than gears, move the laser back and forth to spread the alcohol and then the oil.
I applied some Hopps gun oil to the bearing on the top of the cd clamp, the bottom spindle and the rails for the laser and the drawer. No more skips! I now have a pretty eclectic CD/DAC combo running in my office setup. I have the Esoteric P10 working with a PS Audio Digital Link Gen 2 to my McIntosh C42 and MC162. I still use my Schitt Modi 3 for my streaming (which is most of what i do). Thanks to all for the info!
Hi.
Can you help me on below matter: There is a pioneer DV 515 DVD player. Plays DVDs without problem. It skips and or hesitates to identify on some CDs . The same skipping CDs can be played on another player without problems. On the DVD integrated board there are two adjustments one for master clock and other for VCO voltage. I was unable to check the master clock frequency but the VCO voltage is at 1.9 Volts when playing a CD. It looks ok. On the laser pick up there are two pots but I did not touch them should I be tweaking them a bit to solve the CD issue? If yes any suggestion for working without oscilloscope? Thanks.
Any ideas where I can get a set of belts for a Yamaha CDX750E ?
I was having an issue with this player in that when you put in a CD and close the drawer the motor wouldn't run, (just a couple of twitches from the CD), the laser head would pump up and down a couple of times and then the CD would be ejected. And also at seemingly random other times the CD would be ejected - or at least the drawer would open. I think I might have traced this to a faulty connection in one of the multi-way cables that goes to the laser head assembly. I removed the PCB end of the cable and plugged it in again, and we get motor run, and I can see the laser (which I couldn't before) and the CD isn't ejected. ;)
So now, having traced the problem (famous last words), knowing (from this thread) that 'drawer open close issues' could be due to loading belts - I want to fit a new set (still have originals in the unit) - so I might as well give it a full set - hence the enquiry.
Any comments or help much appreciated.
Hi.
The problem is with the laser. The 2 adjustments on the laser are for laser power and you need an oscilloscope to adjust them. If you make it too high you will destroy the laser. There are 2 lasers in there, one for DVDs and one for CDs. Most likely the CD laser is bad.
You have to measure the belts and buy something 10% - 20% smaller. My go to belt guy is Vintage-electronics.net. I don't know any sources in England.
Thanks for your reply. Is it possible to know which one is which? LHS one or RHS one?
Thanks Warren :thumbsup:
Update
After more testing the problem came back - and I heard the dreaded 'sizzling sound'. So, according to post#1 my disk motor is bad. :(
Unless, the actual fault can cause an apparent disk motor failure?
Any thoughts Warren?
No. That's the other reason to have a scope, you would know immediately if you adjusted the wrong one. Usually if the laser power is low, it means the laser is going bad. You can increase the laser power to compensate but it's temporary. Sometimes it lasts for a few months, sometimes 30 minutes.
Update
If you hear the sizzling and you give the cd a little turn and it starts spinning, its the motor. If you look on the side of the motor there is usually a little sticker with the part number. rf something is a Mabuchi motor and there is a good chance of finding NOS replacement. MD (MN maybe?) something is Matsushita. Those are junk and should be replaced with a Mabuchi, but the center to center spacing on the screws is a little different so you have to get out your Dremel.
Thanks again Warren, still suspecting an intermittent connection? I unplugged the 2 multi-way connectors and very sparingly applied 'Corrosion X' to the connector pins on the laser assembly, and also on the pins at the PCB end - I removed the 3 mounting screws and had a good look around the motor/loading assembly and found the 3 motors, ;) but so far I haven't been able to see any belts?
It's not obvious to me how to dismount the tray for a better look, so I remounted the assembly, and rather frustratingly I had it playing a CD 3 times in succession with no issues, after 2 times I ejected the CD and it restarted perfectly. I have also had it sitting on the bench powered up for two or three hours doing nothing, during this period in the past, I would have expected it to have opened the drawer by itself at least once.
Sitting by itself idle and suddenly opening the drawer could be a dirty switch that senses when the drawer is closed or it could be a noisy motor driver IC. Intermittent problems are a bitch.
Ok. I got the message. Thanks for your replies.
The primary idea I'm getting from the thread is this:
If the player malfunctions, and a belt, clean and lube, or other simple fix not requiring a major component or overhaul doesn't get it going and you aren't emotionally married to it, retire it for a replacement and repeat when that time comes.
Yep, I'll keep plugging away - thanks again for your excellent informed help and guidance, I don't know what we'd do without you. ;)
I think I might have found something, I decided to change some of the filtering capacitors around the motor control IC, and when I got it back together again it seemed worse! While reseating some of the multi-way cable plugs on the main board I discovered one (whose other end goes to the 'sled') which seemed intermittent. It wasn't mechanically intermittent, but it is/was extremely sensitive. If I put my finger near it while a CD was playing it introduced distortion and would cut the music off completely. I realised that during previous attempts to pin down this problem I had disturbed this cable and its precise routing past other cables which run nearby. So, now I have made sure that these 8 wires that go to this one connector cross the path of the other nearby cables at right angles, (thus minimising their interaction with each other), and now the problem has stopped happening. ;)
It remains to be seen whether this was the problem all along, but so far (for one day) it hasn't missed a beat.
That cable carries the signal from the laser pickup, sensitive to noise pickup.
Great,large thread. A lot of great info.
If this was already covered I apologise, or if I should start anew please advise.
Rotel RCD-970bx with broken gear.
Replaced gear, also found spindle had slipped. All back together, now it doesn't want to open. I believe there is a home switch or a relay of sorts that tell it when it's ok to open or close.. I screwed up the timing somehow. The motor just keeps spinning to close even after i hit open. It did not do this before my foolery. So, any pros know how to resync this cdm9 drive?
Thank you.
Tom
Thank you.
Tom
You will have to open it up and get it to manually open the tray. Be gentle. Find the pulley that moves the tray and with the power off, turn the pulley and try to open the tray. If it's jammed you probably put the tray in wrong. Carefully remove the tray. I don't know this model so I can only give you general tips. Often you have to remove the front panel to remove the tray. After you get the tray free or if you were able to move it open, open the tray all the way manually, then gently and slowly push the tray in all the way. Hold the tray in and turn the power on. Usually that sets the timing.
Excellent. I think I did that but I will attempt it again in the am and report back maybe with some pics if it may help.
Thanks doc for your quick reply.
Very frustrating to have found/fixed two problems only to make another. However, next time I will remember these spindle trays often slip on these and can be fixed quite easily without complete disassembly.
I think it doesn't help when people forget there's a disk in and then ship it that way.
