Troubleshooting CD Players
Hi - I am new to the board but have lurked for years. Really great info sharing and ideas by members. Thank you!. Seems like a cool place.
I have a near mint Rotel TCD 945AX and the display is extremely dim. Everything works and I can see time, tracks etc, but I need to turn all the lights off in my house to see it.
I have the technical support manual and believe I know what to replace. It looks like an M501 and an M502 or part numbers TR70000042 and DD40001270, Unless, buying the whole display, DD40001269 is a smarter plan.
I checked with Rotel and they said that they do not sell the parts any longer. This is my vintage system and I really want to get it dialed in and am handy with the soldering iron.
Can I buy these parts from another vendor?
Dear dr* audio,
A few questions for you.
I recently repaired my daughter's JVC XL-M403 (single disc tray and 6 disc magazine) CD player. I was able to disassemble the unit and found the spindle gear that moves the CD's to the laser had fallen off of the motor shaft (see pic). Not sure how this happened but the plastic spindle gear did not appear to be cracked/broken. I pushed it back on firmly, cleaned the laser, oiled the sleds and Deoxited the switches. Once reassembled, she now plays perfectly and sounds great.
Questions:
- Is that amount of grease on the gears normal? Seems like a lot to me.
- Have you seen a gear come off of a motor shaft in the units you have worked on? Any JVC experiences?
- If the spindle gear spins off again, should I try some glue/loctite to keep it in place? If so, any recommendations/name brands?
I'm assuming the spindle gear was a press fit on the motor shaft and quite a bit of torque would be needed to spin it off. It's quite a bit of work to get to this part of the CD player, so if I have to do it again, I want a permanent solution. Just being proactive since my daughter is happy to have a functioning unit again.
Thanks again for any assistance you may be able to provide.
A NAD C521BEE does not spin the CD when the drawer closes.
But when I gently move the laser a tiny bit towards the motor, and THEN insert a CD all things work as normal.
What is wrong in this case?
A Denon 1520 - the drawer wont close the last inch unless I help it. Drawer belt?
Probably. I have three 1520s and was having that problem with two if them.
I installed new belts and one improved and one didn't. I need to revisit as now one of them makes a dull grinding noise for a fraction of a second after it completes closing.
I love the sound of these players though.
@Drugolf so I looked a little closer.
The bottom of the two belts on this machine was still the old belt. As the drawer closed, the brass wheel(?) would continue to turn a little causing a rubbing sound.
I replaced this belt and it seems to be fine now. It gave me trouble when I originally changed it. I ordered these belts on eb from "overseas" and they seem to be ok.
Hopefully this will be the end of this problem.
If you order new belts and need any assistance changing, let me know.
So I've only peered into the Tray and saw the one belt. There are 2?
So I've only peered into the Tracy and saw the one belt. There are 2?
Yes. One top one, longer and thinner, and one bottom one, shorter and thicker.
The top one you can access by opening the tray and turning the power off.
The bottom one you need to take the faceplate off. That's the one in the picture.
Dear dr* audio,
Questions:
You said the gear is cracked. That's why it came off. The gear is nylon, only a very special expensive glue will work on it.
You have to get the special glue or get a replacement gear from a dead unit, or find someone who can make you a 3D printed part.
The home switch may be dirty or the sled motor could have a bad spot, or the slides could need to be cleaned and oiled.
The laser isn't closing the home switch. First thing is to measure the resistance of the switch when the laser is in the home position. Turn the power on with no CD in the player and then turn it off, then measure the switch. If it isn't close to 0 Ohms clean it with a piece of paper soaked in Deoxit.
Nylon, or acetal/ Delrin?
I would try cleaning and relubing the rail the laser rides on.
The NAD C521 plays OK after the moving laser trick, so why would that fix the situation?
Would this situation indicate that some switch for the laser assembly is dirty or otherwise not OK but that this switch is not needed when the laser seeks towards the area of interest?
Currently the player does not even respond to the trick of moving the laser a bit and then inserting a CD.
After closing of the drawer a `buzzing` sound can be hear for a little while.
Would a part like at https://fixpart.nl/nl/appliance/view/739328 fix the issue?
Or is the problem more in/around the drawer assembly?
Would there be someplace that has pictures that show where these parts are?
I can take off the top part that holds the top spindle thingie.
Where would I have to look for the switch you mention?
Additional info:
When the drawer closes I can hear a buzzing sound for a few seconds.
When I tap on the back end of the drawer assembly during that time the disc spins up and the player operates as normal.
What would this indicate to be faulty?
When the drawer closes without a disc, the player spins up twice without the need for a tap.
I assumed it was plastic, but Dr. Audio is most likely correct when he said it's nylon.
I could find no cracks on the gear and the player is functioning fine now, but are you aware of an inexpensive glue to bind a nylon gear to a metal shaft?
Regular cyanoacrylate "super glue" should, work for nylon, iirc, but is ineffective for acytal/Delrin.
Additional info:
This indicates a bad loading belt. The belt is stretched and slips, and it can't raise the mechanism into the play position. Go to https://www.hifiengine.com it is free to join. Go to the library page and search for the service manual. The manual will tell you where the loading belt is.
It will make a weak bond. Possibly good enough to keep it from slipping on the shaft. If you want to find out how hard it is to glue nylon, try working on an old Nakamichi cassette deck where the nylon stand offs are broken.
  • Like
Reactions: j!m
