Troubleshooting CD Players
I don't have an oscilloscope. Is this something that I could experiment with without it? I did get a manual for it today. It looks like the only adjustment for the output is "output offset" which I will check with my multimeter. Other adjustments listed are "Tracking offset", "Focus (DC offset)", "Focus balance", and "Tracking error balance." Adjustment pots are all on the main PC board.
Ok, I did the output offset. The numbers I was getting were VERY off. Both should show 0mv. I measured 40mv on both channels. With a small tweak of the adjustment pots, both are 0mv. Thus far, a big improvement in overall sound. Deeper bass, more impact, and the treble is much, much more tame. Someone was driving the outputs quite a bit too hard!
You can't do this without a scope.
I figured. I am impressed with the improvement in sound simply doing the output offset adjustment. My bass is better and the treble isn't breaking up like it was. There's still some of that "shimmering" sound, but it definitely seems better. I tried a few more discs and they all read rapidly and searching between tracks is very fast. Until I get my hands on an oscilloscope (What's a good one to get?), I'll have to be happy with what I've got so far I think.
Good to know. I'll start taking a look at them. I'll have to figure out how to use one, but I've figured out plenty of stuff on my own, so it shouldn't be the end of the world. As I try to expand my electronics horizons, I guess an oscilloscope is probably a great tool to have!
IMO, the Rigol DS1054Z is the best bang for buck 4 channel scope going around.
You could still get a Rigol DS1052E which is even better bang for your buck if you only need 2 channels.
See the EEVblog review above of the 1054Z.
I recently bought the DS1052E, and it’s great.
Mr Relish
So in looking for oscilloscopes, I realized I have no idea what to look for and what I don't need. Do I need 2 or 4 channels? Since I will be learning how to use it, are there tutorials on these? If I'm going to spend the money, I want something that will do what I would want it to do in normal scenarios and also be easy to use.
@dr*audio
I'm working on a Yamaha CDX-1030.
I replaced the belt so it could load the disc, then it was skipping backward on some tracks. I cleaned and lubed the rails with sewing machine oil. That seemed to fix it, but I'm not sure it is 100%. Now sometimes it doesn't read to the end of the disc, it will stop prematurely. Any ideas?
Raccoon1400
Did you put a couple of drops of oil on the spindle motor upper bearing ?
I did the rails and the motor, which fixed the skipping on my Yamaha CD-1050, but the rails weren’t that bad. The motor was much smoother after oiling the upper bearing, and I think, but can’t verify, that this was the problem on mine.
Mr Relish
Ok so i have a vintage portable cd player that has an issue. Basically It has static/distortion when playing a cd through the headphone jack but when using the line out it works perfectly with no static. I would also like to note that if i hit pause on the cd player the static disappears but once you hit play it returns. I tried some compressed air in the headphone jack and also tried cleaning it out with a q tip. Did not work. Any suggestions? Thanks
Raccoon1400
Mr Relish
I just tried that, I don't think it helped. Also it seems to be near the end when it skips. And not super frequently, maybe a couple times per disc. It has skipped forward a couple times too.
Bought a philips CD 723 cd player about a week ago. Put a cd in, started playing, sounded great. But after a bit it started skipping some, and then it just up and stopped. And wouldn't play immediately after that. Tried another cd. Couldn't read the disk. Waited a bit, and tried another and it worked for a few minutes and same thing, just stopped.
So i've repeated this now on quite a few cds. Not always any skipping involved - if there is, it stops very soon after. Usually just stops after a bit. Any ideas? Where to start?
@dr*audio New issue, my JVC XL -Z1050, with the "paradox" mod, has developed a hiccup on track 2, sometimes 3. Mostly always 3.
I've tried BRAND NEW cds, and usually at the end of track one, somewhere in track 2, or as late as early track 3, it will skip forward, hiccup a time or two, and then continue on like nothing happened.
Seems to play other tracks just fine. I just cleaned the sled with alcohol and put a little sewing machine oil on there. Also swabbed the lens with a q tip to remove any dirt or debris.
Any other ideas, sir?? I spent far too much for this antique, silly me. Had it about 5 months, and just started doing this.
1. Oil the top bearing of the disc motor.
2. Make sure the cable going to the laser isn't hanging up on anything.
3. Could be a broken wire in said cable. Probe it gently with a Bic pen while it's playing, see if it hiccups.
4. Remove any driving gear between the rack on the laser and other gears, so the laser can slide freely. then move it back and forth and see if it hang up anywhere. Some mechs have a piece of plastic the laser slides on, opposite the side with the machined post. The plastic warps and causes too much drag on the laser. If that's the case, sand the plastic down a bit so the laser slides freely.
I opened it up, dropped a tiny bit of sewing machine oil on the slides, and then worked it back and forth. It hiccupped a time or two, and hasn't done it since. Even plays burned discs no prob.
It may not last, but working perfectly since then.
Again, dr*audio, you're the best for being such a resource here. :rockon:
Welp......it's doing it again. I'll pop the hood, see what I can find. This particular model is a mysterious one. Most of my cd players are pretty straightforward, but I'm having a hard time finding my bearings on this beauty.
Hello hoping you can help with my outputs on a dvd/CD player .brand is dual and its xdvd136bt . Now I dont know much about stereos but I hooked up the deck and screen was on although touchscreen was not working .and after hooking up all the speakers I only had one that works.after weeks of ppl trying to help and nothing until a buddy said my outputs were screwed. So question is can I fix the outputs???
