Troubleshooting CD Players
Thank you very much for your reply,
I think I have another laser head so I will change it ASAP and will let you know if it works. :)
Be sure to wear an antistatic wrist strap and ground it during the repair! Also if the replacement pickup is new, there is a shorting solder blob on the pc board of the pickup that must be removed.
You should perform the electronic adjustments after the new pickup is installed, at least EF Balance / Tracking Balance and Focus Bias. You need a scope to do this.
Yes, I know about the static and the solder blob but my major problems are that I never did anything like this, the friend that has the scope and helps me operating with it is out untill January...and for sure has also never adjusted any cd player...
A question though, as I have no service manual
where shall I look on the inside or which boards of it to do the tests you mentionned?
Tks:)
After you clean the rails, lubricate them with a couple drops of light machine oil on either side of the pickup.
Never use alcohol on the lens, alcohol clouds some plastics.
Put a couple drops of oil on the top bearing of the disc motor.
Replace the belt. www.vintage-electronics.com is a good source. Measure the old belt and get one with a slightly smaller circumference.
I did the above and no skipping! This vintage player works like a charm. I have the new belt on order and will install when I get it.
@dr*audio thank you for the help!
Hi. Any pointers on a CD player that opens normally but will not close and needs to be pushed in fully manually, at which point it also plays normally?
Thanks
Hello!
I just bought a CD player that supposedly had never played a CD and had all the original packaging.
I was VERY excited about it and right out of the box it had problems. The good news is that the seller refunded my money AND told me to keep it, so that's good.
The bummer though is that it sounds like this:
When I opened it up, I discovered that if I hold up the rear of the unit, I can get the noise to go away:
It's not obvious to me how I can adjust this thing to get that to go away.
Any words of wisdom? I'm thinking of just ditching it.
Thanks,
Tim
I can't see anything with that pc board covering the mechanism and neither can you. Leave the cd in, unplug the power and remove the board. Then look to see what is scraping. It's probably the chucking magnet that holds the CD. Could be something broke loose inside that is scraping. The chucking magnet should float in the support arm and not scrape on it.
Hello!
Thanks,
Tim
Thank you for that tip! I'll give that a shot; it never occurred to me to do it that way, although as you said, I sure struggled to see what's going on below that board. I'll report back so others can benefit.
Thanks!
Tim
I removed the board so I could see, but it hasn't exactly been a confidence builder with regard to being able to see what's going on. That said, I wouldn't be surprised if the chucking magnet is indeed rubbing on the support arm.
Here's a new video:
With that, three questions:
1 - Now that this is all apart, how can the CD be removed so I can work on it?
2 - What are steps to working on the chucking magnet scraping if that is indeed the problem?
3 - Do you think it's the chucking magnet?
Thanks again!
Tim
Update
1. Teac PD-H500i with laser pickup KSS-210A. It behaves strange (at least for me). When i close the lid, it tries to read the disk but it can't (no disk). If I raise the front of back side of CD few cm's and repeat the procedure, then it succeeds. - I believe it is something wrong with the laser pickup because after first success, it works good after that. I have ordered new pickup KSS-210A, and will inform what happened after its replacement
2. Teac PD-H500c with laser pickup KSS-213C. This player detects CDs without problem, but there are glitches and skipping while playing the disks. It looks to me that it is something connected with the mechanism but I am not sure what. - I have tried everything you told me, cleaned all, oiled it, checked the gears, even opened the Mabuchi motors and polished the collectors and cleaned brushes, nothing changed. The suspension is good, CD is not touching anything. At the end I believe the problem i have is wobbling of the disk and the mechanism. It is not much but it exists and this pickup cannot handle with it (possible it is also weakened). I have ordered the whole mechanism KSM-213CCM. I will replace it and see if it will solve the problem and inform you.
Thank you for your help, you are a real treasure for desperate Hi-fi enthusiasts
Zoran
I have an update about my faulty CDs:
2. Teac PD-H500c
I have ordered the cheapest laser pickup KSS-213C at Aliexpress (around 3$) and the whole mechanism KSM-213CCM (around 10$) to try my luck with them. The laser pickup arrived and I have decided to replace just the pickup even I thought there was some problem with the mechanism. I don't have oscilloscope so I have first measured the current of the old pickup at resistor R315 (10 Ohm) and it was around 78 mA which is very high according data I have found on internet. With lower current CD wasn't reading the discs and with such current it was often skipping during playback. After that I have replaced the pickup, removed the shortcut on it and turned the potentiometer clockwise to the end (for lowest current). I have started the CD and measured the current and it was around 30mA. In that position the unit wasn't reading the CD. I have slowly moved the potentiometer backwards and CD started reading the disk, and leave it around the middle point where the measured current was around 40mA and unit is now reading CDs and not skipping any more. It is working Ok for now. I am still testing it but everything looks good for now. Seems the mechanism was good. The link where I have bought KSS-213C pickup is https://www.aliexpress.com/item/1005001506567953.html?spm=a2g0o.cart.0.0.ce253c00SW6nL0&mp=1, as I have said price was around 3$ (almost for free) and it worked for me and I think it is worth trying for other folks who have similar problems. I am sending the picture of it, you can see it is "Original part" :-) . About the declared current written on the pickup, I seems to me that Chinese put the same label on all this cheap pickups from the same series, so you shouldn't consider the written very much (maybe I am wrong, who knows). On this unit it was written 45.1mA but I will keep it as it is now (40mA) unless I note some problems with the playback. Unit is reading the songs easy, skipping to the next track very fast, so I won't raise the current for now.
The chucking magnet is rubbing on the top surface of the support arm. This means the mechanism is too low. Either the springs are compressed, or the disc table that the CD sits on is too low on the motor shaft. This is a likely cause if the player was shipped.
Put the board back in and then eject the CD.
Stick a flat blade screw driver between the top plate of the CD mech and the bottom of the disc table (the part that attaches it to the motor shaft) and twist just enough to move the table up about 1/16".
Then load a CD and see if the check still scrapes. If it does, raise the table a little more.
Here's a new video:
Thanks again!
Tim
Could you please clarify where you mean to do this? Am I moving that bottom support up the shaft by 1/16" increments? Maybe you can point somehow on my picture?s
Thanks again!
Tim
Thanks again!
Tim
The disc table has a tube on the bottom. That's where you want to pry to move the table up. There is a gap between the tube part and the mechanism, which is too large to simply pry it up with a screwdriver, so find a piece of wood to insert in the gap as a spacer and put the tip of the screwdriver on top of it, to pry up the disc table. Don't try to pry at the flat part that the CD sits on or you will distort the table and the disc will wobble!
Thanks again!
Tim
Thank you!
Unfortunately, I think it's "game over" time. I got in my head that I might have better access by moving the circuit board out of the way, and broke a very small wire going to a multipin connector. Not sure that's going to be solderable, and have no idea how to get to the other end of it to replace it altogether.
Scope creep! UGH.
Hi, I have a NAD C 541i player, the laserunit is a kss 213c.
If I insert a cd it spins up and reads the disc which seems to take a bit longer than other cd players.
It plays the cd from track one to the end but when I try to skip to the next track it spins endlessly but never picks up the track.
I opened it up and can see the laser unit is moving over the glider. Is this something that can be fixed ?
This is the mechanism:
I think you need a new KSS213. BD Enterprises has them. It doesn't matter what letter is on the end, that's the revision number.
