dr*audio
Fish fingers and custard!
Get the service manual and start checking voltages in the power supply, especially the 5V supply for the microprocessor. If you have a scope, look at that voltage with a scope. there may be a lot of ripple on it.
Hi dr*audio and others, I am trying to repair a Kenwood DP2080 which I purchased recently as not working properly. This unit dates back to 1990s I think and is a pretty basic model. It uses a Sharp H8151AF optical unit. I don't have the remote control. I do have the service manual. This one has me stumped. Symptoms are as follows. Standby light comes on when plugged in. Unit will not power up when power switch pressed. However, display lights dimly for a few seconds then goes out. The power switch is a soft press type (click on, click off). The optical unit also moves slightly when power switch pressed. I have checked voltages at various points on pcb when in standby mode. There are some issues due to bad caps in the power supply part of the pcb and I have replaced some of these. This has not fixed the problem. Strange thing is, the observed voltages at various points drop when power switch is pressed and stay at that level unless unit is unplugged. Other things to note: optical unit will return to rest position if displaced and unit is plugged into power. If disc tray is manually opened, will close when unit is plugged into power. Spindle motor sometimes spins a little, sometimes not. The power switch seems to be wired to the display unit and not directly to the pcb. Pcb seems to be always always when unit is plugged in. There is a switch on the back of the unit which says auto/manual and I am not sure what this for. Irrespective, it does not have any effect on the issue at hand. Any suggestions greatly appreciated. Glenn
