classyharlan
Pioneer PD-717
The lens, the glass part, had fallen out of the sled when I got the deck so I tried just dropping it back in. In this state the lens does go up and down on closing the tray.
Upon inserting a disc I hear the lens move once (the lens isn't visible with a disc in), immediately after that the disc starts to spin and I hear sound of the lens once more, then the disc starts to slow down eventually stopping without the TOC being read. From this state if I hit play it does the same lens movement/spinning.
If I repeatedly push play then, although the disc doesn't play, it will spin at normal speed, presumably because the spinning is activated by the lens movement and multiple play pushing means continues lens movement. (?)
OK
OK but it loses momentum quickly (once the lens movement stops)
The TOC is not displayed and the player doesn't play.
When the power is on, with a disc or without, if I put my ear right up to the deck I hear a constant hum, not a sizzle though.
After the player correctly senses the home postion, the focus search starts and the laser pickup lens moves up and down.
OK
If the disc spins, focus search was successful and the player achieved focus lock.
The pickup may be good. If the table of contents is displayed but the player doesn't play, the pickup is either bad or the internal adjustments must be performed.
If the player does focus search and the disc doesn't spin and you hear a sizzling sound, the disk motor is bad.
