classyharlan
The laser is probably bad. To confirm you need to look at the rf waveform with the scope. You'll have to solder wires on to the test points.
This is the rf of the disc spinning.
What is the input set to; mV/div?This is the rf of the disc spinning.
RF looks good, a little low but it might be the disc. I want to see the TE testpoint. 2mS/div.2ms was static so I attached two additional time division photos as well. I'm using a 10x passive probe.
Thank you for your continued help.
View attachment 2462478 View attachment 2462479 View attachment 2462480
50mvWhat is the input set to; mV/div?
The below video is 3 discs on after the other, putting each in the tray and pushing play. Disc 1 is good, the others fail; discs 1 and 3 are 45 minutes, disc 2 is 79 minutes.
Regarding laser strength, is it correct that it doesn't matter what waveform the scope is showing, as long as that waveform is around 1V in height then it's ok?
So for the other deck (Panasonic) that I'm also currently asking about, it just spins and doesn't play so the pattern it shows isn't an eye pattern, but since the height is only 0.1V then that is an indicator that the laser is near dead?
Likewise for the deck in this video, since the waveform height is about 1V even when it fails then that means that the problem is not with the laser?
On a deck with a completely dead laser, will there be no output?
On my deck with the weak laser, since it's on its way out anyway, is there any value in looking at the rf and increasing the laser power?
Clean the home switch or check it with your meter on ohms.It's the gear slipping as the sled tries to move in beyond the home position.
I cleaned the leaves of the home leaf switch with deoxit on a qtip. The meter reading seemed ok both before and after cleaning. The bad discs from yesterday will today play from track 1.
One failing disc from yesterday did not today have problems playing. The other failing disc (the longer one) is failing today when selecting tracks in the middle and beyond. It first moves the sled out to the track. Then it either 1) sticks on the track spinning without starting, or 2) the sled moves back to home and either a) stops, or b) stops and respins, or c) tries going past home, or d) any number or other things that I can't remember well enough to describe in detail.
When it goes back home it either does so e x t r e m e l y s l o w l y taking maybe a minute, or at the normal speed--like after stop is pressed--but with intermittent jerky motions.
I tested some other previously failing discs and they still failed today. I also found one other 75+ minute disc that failed and that I hadn't tested before. I also found multiple other 75+ minute discs that didn't fail and that I hadn't tested before.
I don't think there are currently any normal length or shorter discs that are not failing, it's only failing on longer discs. The failing normal length disc from yesterday was today ok.
The discs aren't scratched. They also play without problem in other decks.It is very unusual for a player to have so many peculiar behaviors when failing. It almost sounds like the microprocessor is bad. If so, the part is not going to be available. The other possibility is the Sony servo processor IC, which is also no longer available from any reputable supplier.
By any chance, are the CDs that fail scratched?
Not directly. We check the other systems and if everything else is working correctly but the player acts like it has brain damage, you can assume it's the microprocessor. Check the power supply for the microprocessor (Vdd) with your scope. It should be 5V with less than 100mV of ripple.The discs aren't scratched. They also play without problem in other decks.
Is there any way for a novice to check the microprocessors?
The other thing to do is try to figure out what the difference is between the discs that play and those that don't, and monitor the rf, the tracking error and focus error while it plays the last track it can play correctly, with the scope, and see what happens when it tries to play the next track. Don't skip ahead, just play the last good track normally and let the player advance by itself. This is what I would do if I had the player in front of me. Hard to do it by remote control. When looking at the tracking error and focus error, put the scope on DC coupled, so that if the voltage starts to climb (more error) you will see it.
What I would suggest first is to find an older prerecorded CD, from the 1980's or 1990's to use as a benchmark, because older CDs have higher reflectivity. Use that CD to adjust the laser output so the rf is 1.5V peak to peak. Now play the problem CDs and see if they play. I use a Sony test CD, but I doubt you'll find one of those.It looks like the rf height differs by .2V between good and bad discs (1V for good and .8V for bad). However there are no other commonalities between all the bad discs or between all the good discs.
The TE and FE seem the same for all discs, except when there's failure in which case the heights of both TE and FE go through the roof.
