MincedMeats
Hi
I recently bought a NAD C 515BEE. The seller promised me that it worked perfectly but.. it doesn't. When seeking through a disc (or scan as it's called on the NAD) it will often get stuck and jump back and forth, a sort of stutter. It varies from disc to disc where it does it or how much it does it. If there is one common thing, then it's that it's usually worst at the end of long discs with more than 70 minutes of play time. It makes no difference if it's a perfect shiny disc or if the disc is worn and has marks/scratches
The local NAD service/distributor says a new laser is probably needed but can that be true? Apart from the seek stuttering it plays everything perfectly, loads all discs fast and with no issues
I would like to clean and lube it. But here's the problem: I have absolutely no idea what oil to get. I see various recommendations for oil with either teflon or silicone. Or a light machine oil. What kind of oil is that exactly? Is it general use oil you can use for lubing bicycles, door hinges and all sorts of other stuff? Or is it some sort of specialist oil? Looking at all the various types available makes it confusing. I've found a brand called Super Lube which I can actually purchase. They have something called "Super Lube Multi-Use Synthetic Oil with Syncolon". Would that work? And if it works, can it be used for both the rails AND the motor?
I live in Europe so I can't just use the actual brand names the US based users recommend. I have to find something that's for sale here
So TLDR: oil is awfully confusing - what to get?
