If they work they are probably ok.oops, what I ordered are OPA2134's. At a buck each, if they are bogus, I can throw them away. If I can figure out how to tell if they are bogus. BTW, I ordered a multimeter/oscilloscope with a 50 MHz range. Gonna have to figure out how to use it......
LM4562 will sound wonderful.NAD 5000 CD player.
Was thinking change the original op amps NE5532 to some giving maybe warmer sound, more punch.
Unplug P103, insert a CD, and measure the voltage on P103 pin 1 and Pin2. Maybe the motor is bad.replaced the sta341m and still acts the same, no change, but I have a scope now
Well, if you have a scope you can look at the rf waveform, it should be at least 1V p-p. If it's less, the laser is bad. I have never seen any Toshiba lasers available. It is possible the laser is not moving to the playable part of the disc. When you load a cd the laser should move to the home position and then move back slightly, so the home switch opens. If that isn't happening the rails may need to be cleaned and lubricated or the sled motor could be bad, or the home switch could be dirty.
Focus Bias. You should really do that with a scope for the best eye pattern.Managed to fix it. Since i was not sure the laser was dead and didnt want to spend money on a manual from ebay, marked all the pots positions and tried adjusting them
Adjusting R104 slightly made the disc spin. Reads and plays CDs now!! Thanks dr*audio
Where do we probe the eye pattern. Not getting anything in my oscilloscope when i tried the 3 TPs in the picture...Focus Bias. You should really do that with a scope for the best eye pattern.
There should be a test point labelled "RF" or "HF". I can't find a service manual for that model for free. You are going to have to buy one and look at the adjustment procedure for Focus Bias.Where do we probe the eye pattern. Not getting anything in my oscilloscope when i tried the 3 TPs in the picture...
yep, it sounds good as of now.. there are some sellers in eBay, will update if I buy one and check it out..There should be a test point labelled "RF" or "HF". I can't find a service manual for that model for free. You are going to have to buy one and look at the adjustment procedure for Focus Bias.
5.2v. I have the motor from a KSS-210A, can use that?Unplug P103, insert a CD, and measure the voltage on P103 pin 1 and Pin2. Maybe the motor is bad.
What does each pin measure? Both 5.2V? One is 0V and the other is 5.2V?5.2v. I have the motor from a KSS-210A, can use that?
Ok, I call measurement error! How can you measure 5.2V across the 2 pins but 0V from either to ground?No voltage or little, dropping quickly to 0 on pin 1 to ground, and the same on pin 2 to ground.
Remeasured.Ok, I call measurement error! How can you measure 5.2V across the 2 pins but 0V from either to ground?
Make sure you have a good ground.
The place where you are connecting your black meter probe is not ground. If you are using the chassis, it may not be connected to power supply ground. Use P106 Pin 2 for ground. Please re-measure.Remeasured.
With cd in very soon after it closes.
Pin 1 to ground, .002v
Pin 2 to ground, .001v
Pin 1 to Pin 2, -5.2v unless I flip leads, then it is +5.2v
I was really careful
