Tube tester: Sencore MU-150
Thank you Brice. I appreciate yor help again. I will give another tube a go, I have many of these 12AX7 tubes from scrapping organs for the amplifiers, speakers and palladium wire from Hammond organs.
Thank you Brice.
I found a 12AX7 tube that was well balanced when tested on my Hickok 600A and installed it. It stall makes a meter swing on power up to a greater degree, but returns to zero more rapidly than with the original tube.
I've concluded that the metervswing on start up is normal.
I can't say that I fully understand the tester circuits, I worked mostly with TTL logic and rack mount mini computers with magnetic core memory. I can follow lines on a schematic and know what the schematic symbols correspond to though. I can still work my Fluke multimeter and Techtronics 475 scope.
I'm 70 yo and suffering from brain rot. I'm hoping making these types of repairs will stave off dementia.
I truly appreciate the help you provide Brice.
Hi Vlad.
You're welcome.
You did well. The MU150 is a fantastic tester, but not that easy to restore and calibrate despite my effort to document it all.
Just to make sure, the tube in this tester is not a 12AX7 but a 12AU7. And yes a slight move at startup is normal, as well as a zero adjustment after the tester has warmed up.
It's all good fun :)
Brice.
Thanks for spotting my brain rot Brice. I did install a 12AX7 tube in the tester. I did put a proper 12AU7 tube in the tester today though. It is not as if I'm in short supply of 12AU7s. I scrapped a Conn brand organ last week and harvested 43 of the 12AU7s from the organ doner.
Eric aka Vlad (a monkey with a soldering iron [and the burns to prove it]).
Again Brice, thank you.
I have not done so yet but I also thought calibration verification would be appropriate.
I do find the Sencore MU-150 is easier to calibrate than the Hickok 600A that I have. Fewer steps with the Sencore than the Hickok but I like using the Hickok more than the Sencore when it comes to testing.
I did find that when setting the low end F signal I had to use my scope. My Fluke model 75 DVM was not sensitive enough to measure the signal. I may give it a try using a Simpson meter that I have. Perhaps it can read in thr 15 milivolt range that is required.
Eric aka Vlad (a monkey with a soldering iron[and the burns t prove it])
