AmCan
Hey, Thanks everyone for the replies. I haven't had a chance to check back for awhile. I just learned how to set for email notification. I knew the 7199 was a different tube configuration and that it didn't match up with the other recommended tubes but I also didn't understand why. The 7199 has the same pin configuration, meaning 9 pins, so thanks for the explanation about the heater pins being different.
I have given the JAN 5670 more time to burn in and it isn't cracking up anymore and is starting to sound really good. You got to understand that for me I am not a believer in burn in time for SPEAKERS or SOLID STATE equipment. I do, however, acknowledge that tubes are different and need to be both warmed up and broken in; I just don't have experience with them. The Russian 2C51 and the stock 6N3 I find to be almost solid state like. Because the JAN has improved with burn in time I will risk investing more money on one of the GE stars or WE 396A.
I have another question. If I use the DAC-09 as a preamp will the optical input still work or does that limit me to using only the analog input?
Thanks
Thanks
