Too many - tuners, that is. Here's a few somewhat in order of preference (some rebuilt, some modded, some stock, all analog):
Kenwood:
KT-7500 (recapped and modded, great bass, superb local reception with new matching IF filters favoring local, highly accurate analog tuning that never drifts)
KT-7500 (completely stock and works great even with dial lights out)
KT-815 (rebuilt and modded for DX-ing use. Good sound and a superb DX unit with a 230, two 180s and a 150 IF filter set).
KT-815 and KT-615 (stock, future projects and/or spare parts)
Pioneer:
TX-9100 (pair, both recapped and both excellent on local broadcasts)
TX-8100 (recapped and pretty good sounding too)
TX-7800 (re-capped and excellent for AM with AM wide/narrow switch, good for FM)
TX-9800 (two of these, both re-capped and both excellent sounding but don't hold alignment very well)
Sansui:
TU-717 (recapped, excellent sensitivity and great audio quality - almost as good as the modded Kenwood KT-7500)
AU-D9 (recapped, excellent audio quality, half the push button presets don't work)
Marantz:
150 (recapped, OK as a tuner, needs better alignment, CRT is awesome to watch)
115b (recapped and excellent sounding tuner)
2120 (recapped, OK but nothing special)
Overall, the better Kenwoods are my favorites, the high-end pioneers are close behind, the Sansuis are excellent, but the Marantz tuners are inferior - except the Marantz 150's 'scope is just plain fun to watch. Separate analog tuner units are generally superior to analog receivers from the 1970s era, but some of the Pioneer receivers have pretty good FM tuner boards.
I use a 14-element FM boom antenna 30-feet up on a tower with a rotor for DXing, and have pulled in good FM stereo signals from at least 120 miles distant with this setup on good analog tuners. Those cheap, omni-directional rooftop antennas with two aluminum ovals crossed at 90 degrees work pretty good too in a pinch. Di-pole antennas are just basic and must be moved around as they are directional, but a great tuner will use those pretty well. In fact, a great tuner will work fine for local FM stations with just a six-inch wire stuck into the center of the 75-ohm socket.
