Edit: this problem doesn’t just happen when the needle drops. It also happens from time to time while a record is playing. It happens on some records more than others. If I very slowly drop the tone arm, it is less likely to happen than if I just flip the lifting lever down.
This just started happening and it doesn’t always happen but it happens a lot. Player is a Dual 1229. Receiver is a Pioneer Elite from approximately 2008. Analog outs are shielded Morrow Audio interconnects going into a Parasound ZPhono preamp. Ground goes from record player to the ZPhono - I think I get a hum if run differently. Lately (it’s winter here, so static abounds) if I lift the cart off the record and then put it back down on the record, it causes what I am assuming is one of the relays in the receiver to switch off for a few seconds and then back on.
I don’t even know where to start In troubleshooting this issue! Any ideas?
