If the relay is being tripped while music is playing, and not just when the needle is dropping, do you think that could be a subsonic pulse? It happened a bunch of times while playing an Oliver Nelson jazz record but only happened once while playing Moondance. It seemed like certain parts of the music caused it to happen. When I lifted the needle and very gently placed it down on an earlier part of the record, it seemed like it was happening over and over again at the same point on the record. That was just an observation/speculation and not documented.
two ways. Mostly I started using the mute switch on my preamp before messing with the arm. I also added a subsonic filter to the mix at a later point.
