Unique & Distinctive Speakers
VMPS Audio
www.vmpsaudio.com
Ribbon Monitor V60...nice woodwork :thmbsp:
RM/X (Ribbon Monitor Extreme) - "Elixir"
I can see this thread is going to be very interesting, and humourous too. I am glad some of you find the Technics SST line interesting. I hope to find some more info on these at some point, perhaps from someone who owns them, or at least has heard them. :D
When you all get a chance, you must check out the Eminent Technology TRW-17 sub. This is more of a technological wonder than an artistic one, but interesting for what it claims it can do, and how it looks (think plane propeller). They say it "...requires no equalization to achieve flat response to below 1Hz." Here is the link: http://www.eminent-tech.com/main.html
I actually heard that thing. It was scary. Lowest frewquencies I ever heard from a transducer.
I'd love to hear it. :yes:
Long-term(ie when I build my next house).I will have two of them installed(Stereo ya know...).
Too bad Adire is out of business, nothing moved air like a Parthenon.
Had to look this one up...WOW!!!:yikes:
"...A 53L of displacement version of this driver is capable of can produce more than 120 dB of SPL from 11 Hz and up if you've got an anechoic room for it. When measured at CES 2004, over 134 dB SPL was produced at 11 Hz! Unbelievable. Designed for use in infinite baffle and dipole applications, you could really shake a theater with this thing."
- "Adire Audio Parthenon - Revisiting the Ultimate Subwoofer", 03/25/08 by Neil Middlemiss (http://www.audiojunkies.com/blog/1201/adire-audio-parthenon-revisiting-the-ultimate-subwoofer)
So true.
I'd go over to Adire on the weekends when they were "officially" closed and Dan would be messing around with one thing or another. The Parthenon was like no other when it came to outputting bass. We even had it at a DIY Meet I organized some years ago. As is pretty evident, a lot of engineering went into the Parthenon and it resulted in what you see. In the bottom picture that Yamahalic posted (BTW: thanks!) you'll see some strange coil springs that required a lot of research, to first find the right alloy, and then to design a configuration to move the distanced involved. Two of those springs also carry the signal to the "voice coil", a kind of original dual purpose thinking that was abundant in the design. I might add that Dan told me that these springs were the hardest elements to get right in the whole design.
But, it is impressive!!!
Best Regards,
TerryO
