Unique & Distinctive Speakers
SUPER SUB - QSC ISIS 215SB Subwoofer
Here is one interesting POWERful sub from QSC (mostly known for their commercial products). Here is info, specs and a photo:
QSC ISIS 215SB Subwoofer---
The cabinet of the 215 enclosures is constructed of Composilite™ carbon fiber and composite materials, which is extremely stiff and strong. The high rigidity of the cabinet walls raises the enclosure's natural resonances to frequencies higher than the subwoofer's operating range, so the cabinet acts more like an ideal enclosure.
Frequency Range
- Recommended Bandpass: 35 Hz- 150 Hz (±3 dB)
- Frequency Response: 36 Hz - 360 Hz (-3 dB)
- Usable Frequency Range: 29 Hz - 440 Hz (-10 dB)
Maximum Output
- Calculated Peak Output: 141 dB SPL*
- Measured Continuous Output: 131 dB SPL**
Impedance
- 4 ohms (nom.) 3.7 ohms (min.) 23.3 ohms (max.)
Power Handling
- 1300 W RMS, 2 hours (AES)
- 1000 W RMS, 8 hours (IEC)
- 800 W RMS, 100 hours (IEC)
Sensitivity
- 101 dB half-space, 95 dB full space, 35 Hz - 100 Hz, 1 W, 1 m
Nominal Coverage
- Omnidirectional (100 Hz)
Transducers
- Two 15 inch (394 mm) high efficiency subwoofer drivers.
Weight
- 175 lbs (79.4 kg)
Overall Dimensions
- 40" W x 26" H x 25" D
* Calculated maximum peak SPL at 1 meter distance, half-space, speaker operating at rated RMS power with 6 dB crest factor pink noise input, 35 Hz - 100 Hz.
** Measured maximum RMS SPL referenced to 1 meter distance, loudspeaker operating at rated RMS power with 6 dB crest factor pink noise input, 35 Hz -100 Hz.
I can see this thread is going to be very interesting, and humourous too. I am glad some of you find the Technics SST line interesting. I hope to find some more info on these at some point, perhaps from someone who owns them, or at least has heard them. :D
When you all get a chance, you must check out the Eminent Technology TRW-17 sub. This is more of a technological wonder than an artistic one, but interesting for what it claims it can do, and how it looks (think plane propeller). They say it "...requires no equalization to achieve flat response to below 1Hz." Here is the link: http://www.eminent-tech.com/main.html
that's clever. A motor attached to a magnetic clutch to regulate frequency. Anyone have a busted up alternator:scratch2:
hard drive speakers..
How about absolutely everything at my friend Scott's place? That includes my avatar.
www.sgcustomsound.com
je
RITHM by Davone
From Denmark, the Rithm uses a very high resolution coaxial loudspeaker driver in combination with pressure-formed wood cabinetry. As a point-source loudspeaker, the Rithm presents a very precise and balanced soundstage populated with organic acoustic images. Delivers controlled and tuneful bass into the mid-30's.
Magico Model 6 (More Metal :-)
Attention Metalheads (like me):
Here is another one of the very cool Magico line...the Model 6. This is one cool black beauty. It would fit in the 2001 A Space Odyssey movie. It is made from a a 6061 T-6 aluminum structure :D
Dimensions: H: 54" (138 cm) D: 34" (87 cm) W: 22" (55 cm)
Weight: 650 lbs (294 Kg) :drool:
Driver Complement:
- 5" Motion transformer tweeter
- 5" Nano-Tec pure midrange
- 7" Nano-Tec midbass
- 3 x 10" woofers
Sensitivity: 91 db
Impedance: 4 ohms
Frequency Response: 26Hz-50KHz
Recommended Power: 50-500 Watts
http://www.magico.net/?d=03_Products/05_Model_6/index.html
About 1984 Allison speakers hired a design firm to create new speaker cabinets with a more modern design compared to their rectangular speakers.
Uh, OK I think I must be missing something here. The speakers in your picture look very rectangular to me. Does this mean the hired design team failed?
I got lots of weird speakers.
What are you looking for..........70's/80's/90's type of weird?
I started this thread to gather, to the greatest extent possible, a list of every unique and interesting speaker known by our AudioKarma community. I found a few lists here and there, and I was amazed by the incredible designs that I came across, I realized that a lot of companies (and brands and designs) have come and gone, so now perhaps we can all share our findings between us, to know what is and was available.
All eras of of interest to me. Perhaps you might show us all of your speakers a little at a time to help keep this thread fresh (that is what I am doing)? Any info on them makes for great reading. Thx.
YAMAHALIC
More metal...SONICWELD SPEAKERS
The active "Pulserod" tower and "Subpulse" sub are made from CNC-machined solid aluminum :D The tower houses 13 drivers, and the sub a single 15" driver. Interesting design and tech, you can read about them at...
http://www.sonicweld.com/
The Vienna Acoustics aluminum series are very interesting looking as well, and sound GREAT.
je
Still More Metal...TECHNICS SB-F40
I recently came across the Technics SB-F40 on some vintage Technics websites. These are very cool, all metal, bookshelf type, extended high freqency studio monitors as near as I can tell. One thread explained them as Technics answer to the (in)famous NS-10s, with high frequency extension to an ear splitting 35kHz.
3-way bass reflex / sealed system
14cm low-range driver, 5.2cm mid-range driver, 2.8cm high frequency driver
Impedance 8Ω
Output sound pressure level 87dB
Frequency band 75Hz~35kHz (-10dB)
Crossover frequency 1.5kHz, 5kHz
Weight 3.5kg 3.5kg
