I've never used Flex Seal, but if it will give a reliable airtight seal then it should be fine. You could probably also use silicone caulk, epoxy or wood filler.One other question. The enclosure had a grill cover but it is missing. Now there are 4 fairly large holes, which are through and through holes, where the grill cover pins were. I was thinking of using Flex seal liquid rubber to seal the holes. Any thoughts and recommendations?
