JonL
Lunatic Member
I have finally finished the two I've been working on for a few months. Both passed the dim bulb test with no tubes, and then with the rectifier. Voltages with the rectifier in place all looked good, so apparently no major wiring issues. I've put a full complement of tubes in one, and tried to set the bias. Like others have discussed in this thread, I had to tweak the resistors in the bias circuit to get enough negative bias voltage. That done, I hooked up a speaker and a WA-P2 preamp (after bypassing the heater balance circuitry, and I'm using my phone through a USB dongle for a source. (I'm doing all this work where I'm living away from home on weekdays due to taking a job too far for a daily commute.) I have a couple of problems and questions....
1. When I turn the preamp volume up past a fairly low volume, the amp starts motor boating. Sometimes it stops if I turn down the volume, other times I have to disconnect the preamp. Although the preamp is totally unrestored, I suspect the problem is in the amp. I was able to get the amp to begin motor boating by wiggling one of the 12AU7s to generate dirty socket static. Once that started I had to turn off the amp. Any thoughts where I should start looking?
2. The bias transformer I used has a center tap on the secondary. It is not wired to anything. Should it be?
3. The 3k ohm/2W resistors have gotten very hot and are already discolored after less than an hour of run time. I measured the voltage across them, about 55V, which calculates out to about 1W. Any issue here?
4. I am also using the Sheldon Stokes board, modified with the help of Nerdorama. Some of the caps on the board get a little warm. Not hot, but warm. Issue?
I'm looking forward to finishing up number two and getting them home where I can really put them through their paces.
Tubes in the running unit are original (or at least very old) Tung Sol 12AU7 and low hour Philips 7581 that I had in a Super Reverb for a short while. I also have the original KT66 from the amp, but thought I'd start with the Philips. I'll probably grab a quad of JJ 6L6 for these after I'm sure everything is right.
