Final thought on the Pico ground clip. The com side of the sig gen cable is connected to com of the scope probe connections so I don't think the probe ground needs to be connected with the sig gen providing the ground ref.
Hey all, I've never heard a W5M, but have heard and used an AA-100 integrated. My question is how close would the 100 get?
I have a line on one which was recapped in 2018 and looks very good. JJ outputs which are the only thing holding me back; coupled with the fact that I've been plenty happy w/ my mosfet amps.
Finding W5Ms and then servicing them correctly is a much costlier endeavor but is it entirely worth it versus the AA-100?
Question @dcgillespie :
To eliminate the output pulse, you've suggested installing a small relay to interrupt B+. I'm curious, would using a relay to instead short the 16 ohm tap to ground, and therefore interrupt the NFB signal accomplish the same thing?
Dave will surely provide the correct answer, but it was my impression that the turn-off pulse was potentially damaging to the output tubes. Shorting the secondary wouldn't prevent this, would it?
There doesn’t seem to be a turn off pulse after implementing all of his mods to the W5. I’ve done 3 pair so far.
