In the underside pic, it is mounted by a nut and bolt through the center mount hole of the choke at the top right of the pic. The 1K gate resistor is soldered directly to the gate terminal, and then a green wire to the other side of the resistor. A red wire is soldered to the drain terminal, and a black wire to the source terminal. Then the terminals are covered with heat shrink and the MOSFET is mounted with a dab of silicone grease. At the other end of the leads, the red drain lead connects to the 4.7K resistor, the green gate lead to the voltage divider, and the black source lead to the screens. There ya go!
