Here's a pretty clear picture of what the tape strips look like. You can see the vertical stripes where they overlap on the film.
I see, thanks! Guess I was just looking at the part of the racetrack that's on the other side of the diaphragm!
I plan to do this tonight while I'm pulling the EMIMs in order to change out the old diaphragms and test the felt stuffing.
To help clear the tape thing up, it's not just the tape strip down the center. Those EMIMs have vertical strips of "scotch" tape across the entire diaphragm, from one side to the other. It was their means of damping resonances. Later EMIMs do not have tape strips, but have a layer of another material sprayed on them to do the same thing. I had to remove the layer/tape in order to do the analysis of the films themselves. In either case, it adds mass, which slows the diaphragms down. For what it's worth, Graz uses a completely different means of damping, which I think is quite clever.
I'm not claiming to be a blind tester, and I'm just giving my impressions, take them or leave them as you wish, no offense taken either way. I'm sure the transient response could be measured by someone with the right equipment to take time domain measurements, but that's not me. I'm already spending way too much time on this at the expense of work and family. My goal was to get someone to make us replacement diaphragms; we are there now, so the goal has been reached. I feel they are also an improvement, but the only way for you to know is to try them out yourself, on your systems.
Do the EMIMs look better to you guys than I think they look? It's great that they produce sharper transients... but the overall frequency response? Graz's certainly looks much better than the stock EMIMs.
What do you do with the 8db valley before before the EMITs take over?
What are the steps in Hz on the graph between 100 and 1k, and 10k?
I'm sorry, fellas. Discovering the apparent weaknesses of the EMIM after all this time is a little disheartening.
It's easy to do with nearfield testing. Set the mic right up near the speaker diaphragm and use a program such as spectra lab etc to do a frequency sweep
Nearfield testing of a woofer in my RS-4.5 this morning with an HP signal generator and the Radio Shack meter yielded some interesting results. While there were some minor dips, the more compelling result was 2 large peaks, each at least 6 dB in amplitude, one at around 80 Hz and the other at 100 Hz. Not what I expected but these must be factored into any equalization intended to address a suckout in the low end of this speaker system.
That sounds like a fault of some kind. Do both speakers measure the same ??
From memory when I did the tests on my speakers the dip at around 60Hz was only 2 dB down from the 2 peaks either side of that frequency and not at 80Hz and 100Hz.
regards
Yes, both the same. Who knows maybe the caps have aged in the crossover? One thing I have not done yet is to completely remove the crossover boards and check the seal of the cabinets where the woofer wiring is routed; it is possible this seal may have have deteriorated (as yours did) and is causing some anomoly in low frequency response.
Yes this is quite possible so worth checking.
3 of my woofers have a rubber surround and one has a foam surround. Foam is ok as long as it's a closed cell construction but rubber lasts a lot longer
regards
adding rubber where foam was originally has been known to change the sound in some instances. i think that must indeed be taken into consideration in these response plots.
