Raphaz
I recently got my receivers (a Yamaha R-2000 and a Nikko 1219) serviced. So now the upgraditis bug is creeping up on me.
I know I can do better with my mains, currently a pair of KEF Q500 (with an added Klipsch 12” sub).
It’s a wide open, tall warehouse-like space (high ceiling, wooden floors, big windows and brick walls), and even with remotes helping to fill some of the far corners, I could upgrade the KEFs with towers or stand mounts that fill the space a bit more.
I’m listening to vinyl and streaming services, and I don’t have a particular sweet spot. All sources go into a Wiim Pro+ and from there to the receiver that feeds the wired mains and sub, and at the same time to the wireless remotes (the Wiim does a pretty good job with delay and room corrections).
Besides slightly bigger floor standers, I wonder if stand mounts with tall stands could work. I could also imagine to use the B channel to add a pair of smaller wall mounts, if that helps.
I like the KEFs, they’re really good: clean, even tempered in all frequencies and pretty accurate and detailed, but sometimes they feel a bit tamed, compressed (if not boxy) to me.
And at lower volumes they just don’t project far enough.
One of the challenges I have is that, where they stand, off one of the shorter walls, I can’t have them too wide apart, they can’t be too big and not further than 2 feet away from the back wall. Unfortunately there really is no better spot. I tested with toeing them in and out and I believe the current angle is as good as it gets.
I want to cap my budget at 1.4 K, new or used. I’m open to vintage but there’s always the risk of added cost for hidden damage, reframing, replacing rubbers, recapping…
From what I understand, horns for the tweeters would help with filling the room. Klipsch RP series may be interesting, good value for the price it seems, but people complain about harshness and fatigue and I’m not sure about build quality, may be ok.
Not sure if upgrading to slightly larger KEFs would be an option. Maybe one of the R Meta line, but that may be over my budget, even used. And after a huge disappointment with LS50 (1st gen, not metas) as remotes I have some reservations with more recent KEF products.
There are too many other brands to consider: Focal, Sonus Faber, Triangle, BSP, Monitor Audio, JBL, Burchardt, Walsh, Arendal, Altec, Fyne, Harbeth, Tannoy, GoldenEar… I’m sure there are more. But I need to narrow it down. I may not be able to test-listen many of them.
I was hoping to get some help with narrowing it down to a handful of brands/models. Any advice is appreciated, thank you.
