AccidentWhy the repost
@Raphaz : I'm really trying not to be too negative, but in your case it's tough.From what I read the Ohms would help with the sound a bit, and I thought they are less picky with placement
Happens to me every now and then on the phone - not sure whyWhy the repost?
Got it. And appreciate it. Thank you.@Raphaz : I'm really trying not to be too negative, but in your case it's tough.
Yes, the OHM's are less picky than the average speaker in the average room.... but you room outlay is far from average, so if you can't capitalize on a speaker's assets I don't recommend you spend the money. I'm not sure they would sound significantly different than your Q500's.
Yes, great idea; your KEFs are way too close together now.I wonder if I can bring the main speakers forward a bit and the left one in front of the stairs
She's generally very supportive, but sounds like a brilliant plan.Try a temporary setup using boxes or similar to raise the speakers. Just make sure to tell the wife it is an experiment and you might get away with it long enough to learn something. I was able to keep my ZU DWs in the formal family room for six months.
Where is your listening spot? L/R speakers should be on the same plane, meaning they should both be in-line. If not you will get phase shift from L/R. Get some blue painters tape. Tape the floor where you put them. Move around, placing tape each time, mark the tape with your thoughts. Do not do any toe for this, it will take some time. Once you find a good spot, then mess with toe. 1/2in can make a noticeable improvement.I wonder if I can bring the main speakers forward a bit and the left one in front of the stairs. See attached.
That way I’d get a bit more distance between them and from the wall. The left would be close to where the sub is now (which is tucked below the stairs). The fact that the sub (slightly toed in) projects surprisingly well into the space makes me hope that the left speaker would work fine there — although the left speaker would be almost in front of the sub which may cause other issues. Sectional and piano would have to move further down into the space.
Probably awkward flow and use of space otherwise. But I got the WAF taken care of for that now, so I’ll do a trial with the KEFs just to hear how the sound changes…
Would not really worry about sensitivity all that much. Horns might work well, they are very good at projecting sound, are good off-axis. Plus they can play loud. At my seating spot, have recorded 111db! it was still clean and listenable.It looks like it's now about finding good stand mounts or taller towers, ideally with at least 90 dB of sensitivity.
Horns or no horns for my space, given the change in placement as in above? I'm a bit confused about that still — some recommend it, some advise against horns. To be fair, not everyone had the same awareness of my space.
On a different note:
I'm not sure if it's just about me, but a lot of speakers seem to sound boxy to me, and often "tamed", meaning the sound seems to come out of a damped, wooden box (which, in reality, they usually do, I suppose). To put it dramatically: snares and toms can sound like cardboard; cymbals have no ring, as if things are almost a bit too controlled. Not sure how to better explain it.
The Q500 does that to some extent, but, depending on placement, it's bearable. The Fluance A61 (which I currently use as remotes in the kitchen) certainly does that (as did the Q Acoustics M20 I test-listened to for the same purpose, and the LS50 non-meta).
One of the speakers that never sounded boxy to me is the Minimus 7 (which, in its size, is still unbeatable to my ears) — maybe because it's cast iron?
I wonder if that's a personal animosity issue, or if it's related to the speaker design and the materials used. I suppose I want to determine if I can avoid specific speaker models or designs if I don't like that characteristic. Very personal, I know...
Thank you all again for your honest opinions and for sharing your experiences.
Where does the OP name his turntable? He has two reasonably respectable receivers, the KEF, and a Wiim. I don't see anything else mentioned but my eyes aren't so good.Might not be the speakers, but the source. This is called a "non-revealing system" If the speaker are muddy, they need to be rebuilt, or they are crap. You do have a low end TT, it will not be reveling. A cart upgrade will help a bit.
Correct. He does not mention his sources (TT, CD, tape and streaming services) anywhere in this thread. But he thinks they are decent, not super high end (whatever that means) but certainly not low end.Where does the OP name his turntable? He has two reasonably respectable receivers, the KEF, and a Wiim. I don't see anything else mentioned but my eyes aren't so good.
Too largeI had a pair of KEF Q900's. That series isn't hard to top but your room is. It's a perfect excuse for some large vintage speakers from Altec or Klipsch. I listed Alted first as that would be my choice. A pair of VOTT's should work.
