Got anybody up there in MN with measurement gear? Maybe a little dorking with the XO or some contour filtering could help make them acceptable.
Ray
OK...
The Delos Surround sound spectacular test disk, a Radio Shack meter at six feet and mystery Utahs.
They are in sealed (epoxied) vented enclosures built from plans by Utah by my Godfather in 1960. Given to me at Easter, all I know is they are 12 inch coaxial Utah's.
I'm listening to them now as I visit AK.
They are the top speaker in this picture. The grill would have to be cut off or the back of the cab sawed off to see what model they are. I guess the plans called for lots of plywood and either left no option for opening them up again, or Lordell went a little over the top in building them.
I bought a hypodermic intended for vaccinating livestock and ArmorAll'd the surrounds.
It was the only way I could get to them.
It made a big improvement, they had made some crunchy noises before. Well, they sat in the same basement since 1972, rarely used.
Freq response, the highest test signal on this disk is 12,699hz, it's 2 db down from 1,000 hz.
Track 19, Low-Frequency sweep with voice over. In room bass gives out at 58hz. No gentle roll off either, it's a sonic nose dive. Though I could hear (faint and useless) 32 hz.
They are easy to listen to, a bit bright, OK detail, wid-ish sound stage. Sensitivity is huge, I could measure it if I felt inclided to drag them downstairs. However my Luxman RV-371 at half volume at six feet, listening to Minnesota Public radio, 104db. that was on a solo acoustic guitar piece....and I might add, way louder than I want to listen to MPR or acoustic guitar music.
I tried pink noise, honestly, at 108db at six feet, they are kinda scary. I felt no desire to turn the thing up all the way.
They didn't distort.
The meter says 70 db now, nice to listen to again. Next up Wagner at 80db (which would be fine except I don't like Wagner), the volume on the Luxman is about 1/10th open.
My Ohm Walsh 300's are in no danger of being replaced, but these are fun.
