Retrovert
Addicted Member
I was trying to help the OP with a simple way of taming the brightness inherent with swapping from the horrible black-bodied, red-ended ALCAP or COLLINS capacitors to new film capacitors due to large differences in ESR. The typical values have been measured before on this forum and others.
ESR isn't the problem.
Electrolytics have poor performance for frequencies above 1k Hz even when new, and the capacitance reduces with frequency. Beyond that, electrolytics degrade with age and cease to function as capacitors. Many even short out. At best an electrolytic rectifies the signal, causing distortion.
A brand-new, low ESR NPE will not have the same sound of a PP film, particularly given that the capacitance will be an unexpected value when the frequency is above 1k Hz. Electrolytics are best used for power supply filtering, not signal path uses.
Yes, I should have known better and should have provided details of a proper L-Pad or T-Pad. Sorry I didn't have time to go into this kind of detail - I was posting from my phone at the time.
An L-pad is the easy and proper fix to balance tweeters against other drivers, and that's the easiest and best solution. Adding impedance to the path will shift crossover points, and a few hundred Hz in the midrange is going to be noticeable, given that humans best hear in the midrange.
What happened instead of an L-pad being added is the OP added not the 1 Ω you suggested, which is problematic enough, but twice that value: 2 Ω. That was even worse than your suggestion, as the crossover point has now been downwards shifted by 20%. Using the example I above set forth, the crossover point is now 1,989 Hz instead of 2,487 Hz. That's a downwards shift of 500 Hz!
Now, if that was shift was solely restricted to the tweeter it now overlaps the midrange by 500 Hz, and it is only the reduction in efficiency which doesn't make this "solution" sound even worse, particularly given the comb artifacts from substantial driver overlap.
Electrical engineering is governed by physics which is expressed as mathematics. The formulas do not lie. Anyone may easily calculate the crossover point given the alterations in impedance. Crossovers function as electrical filters and the formulas are well known, easily computed, and not hard to understand. Ad hoc solutions are not desirable.
OP: upgrade the NPEs to PP film, add an L-pad, balance tweeter, done.
