Vintage Entry Level Options
Oh, i can spin the platter by hand, but with the platter off, i cant turn the spindle at all.
Give the platter a spin by hand and see how long it'll run by itself.
If it stops quickly, we've found what's slowing your TT.
If it continues to spin for a little while, then...
We'll want to oil both spots while we're in here, so if you've got your oil handy.
Ok,
It's not a hard fix.
It sounds as if the grease that lubricates that spindle has dried and gotten gummy.
The spindle itself sits in a metal pocket, and rides on top of a single ball bearing.
You can oil right at the base of it like it showed in manual. That might be a temporary fix.
But we'll need to remove the spindle, clean it, and relubricate, to do the job completely.
It's not hard, I'm sure you can do it.
See where it shows to lubricate the center shaft. Get some oil in there and spin it around a little.
Ok, did you put some oil in the motor hole as well?
You're right now at a temporary fix. It'll probably last a while, but I'd recommend pulling out the spindle at some point and clean/relubricate it.
It's up to you if you want to do it now, or wait a while.
I'll walk you through the process when you're ready. I assure you, it's way easier than it may seem.
