Vintage Entry Level Options
Yes i have the preamp
Good.
Do you remember how the cables go?
Turntable RCA to Input on preamp. That other RCA cable goes to output on preamp and connects to RCA in on back of powered speakers.
The ground cable from the turntable which has a spade connector connects to the grounding screw on the preamp
what do you mean, set the overhang?
You want to make sure that the diamond tip of the stylus is exactly where it should be.
Page four, about halfway down shows how to set overhang.
Since it's already mounted, just check to see if the stylus tip is on the white line.
It's more accurate using the protractor, but let's use the instructions setup first.
Then, when you've got the protractor printed, we'll do the more accurate adjustment.
I already loosened them, so the stylus is supposed to come down right next to the white line, as in if the line were extended further, the stylus would fall in the groove?
You want it the stylus tip centered over the white line. Then tighten the screws. They don't need to be 'torqued down tight' just 'snug tight'
As long as that diamond tip of the stylus is on the white line, it's where it should be for the instruction manual setup.
It can probably be even better aligned by using the protractor, but let's make sure everything is working properly first, and we'll do the protractor in a minute.
It's ok if it looks like the cartridge is pushed back a bit, as long as that tip is where it should be.
Awesome, dude. Let's get a record on there and see how it is so far.
With the lever in the up position, move the tonearm so the stylus is hanging above the lead-in of the record. Then slowly move that lever to down so it puts the stylus on the record.
Had a bad hissing sound but realized it was just because the one wire wasnt grounded to the preamp. Overall sounds greater than anything I've heard on cd or on my phone. It seems to get a but muddy as I turn it louder, but i feel that this is because these speaker cannot handle such a strong line from the pre-amp.
Ok, that could be from a variety of things, but at least you've got it working.
First off. What was your first record played?
It may just be from speaker placement too close to the turntable, or just that we need to protractor align the cartridge.
Also, remember that that's not a new stylus on there either. Could be that it's a little worn and about ready to be replaced - the seller mentioned that.
Zeppelin II, i have each speaker set up around 2 feet from the table on either side
With that selection, you have just won added bonus points here.
You could have only topped it had you said Dark Side Of The Moon, or Rumors, then you would have won all the AK internets for the day. LOL
Did you print the protractor yet? Do you want to do the alignment now to see if that clears it up a bit?
