Vintage Entry Level Options
I believe i have it set on 0, need to find gram weight for the cartridge.
For the moment, just turn it in or out until the tonearm is level and parallel with the platter.
That's the first step. When it is, then hold that weight in its exact spot, and just turn the dial on the front to 0 on top without letting the weight turn.
It's on page 6 of the owner's manual.
You downloaded that right?
From what I've found on the net, it looks like 1.5 grams is about right for that stylus - only going by others in that range, couldn't find your exact one.
Page 4 of the manual shows how to set the overhang by using the white line at the front.
Just check it and see how it is.
We'll actually want to use one of those protractors you printed for even more accuracy.
