@cmnparlance
I hear you buddy... Really.. IMHO yes.. the turntables we use are getting old, but there build like they don't build them anymore...
The TT I worked on for myself was dead as a Doddo... I froze over Hell to get it working again...I just wanted to know what caused the problem..
No mine was odd... Someone F***ed up and made a mess for me to sort out... As I understand from you there no word about that ...
So here we go.... IFFFFFF the guy who replaced the caps in your TT did a good job (and that is an IFFF) then you should have no problem replacing the the identified parts and get it properly working again..
So replace the 33 /45 switch... and also see VR1 and VR 2... They are also simple run of the mil adjustable pots. value 5k each..
These three parts are cheap to get, and fairly easy to install if you are capable of soldering. (and I mean electronic's soldering, not copper pipes..)
SO you need a soldering iron good for electronics and some Soldering Tin 60/40 with flux core..the real stuff.
I promise You feel a King when you are done and all functions like it should. Now that would be a good story to share round a campfire
And now the "What if" there always is a very small chance that one of the HALL effect switches in your motor is defect...
In that case you would need to replace the motor... That chance however is less then 20%.|
And even that one is cost effective
https://www.ebay.com/itm/Technics-S...217013?hash=item4b712b66f5:g:2LcAAOSwd9heAIXT
