Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
The OP might consider (probably in this order):
1) clearing cookies and/or history on his or her browser
2) checking for an update for his/her preferred browser (i.e., make sure the browser is up-to-date)
3) try another browser (if only temporarily)
TOS: JaS reported some in the meantime fixed problems with his DNS provider a couple of days ago, when I also couldn't access VE and HFE. DNS related stuff may sometimes take a while to propagate through the net, though - so maybe you're just experiencing that hiccup with some delay...
Tried also on Firefox -nothing ! Can't access hifi engine rither "website not available"
There has to be sommetthing with the server ...
Nice to see you , Manfred !
Use the web site isitdownrightnow.com and put in the web site name. It will tell if it's really down or just a problem for you.
Two:
Open a command window and type "nslookup www.vinylengine.com"
You should get something back like:
Server: dns.yourisp.net
Address: ###.###.###.###.###
More stuff....
Name:
Addresses: This is the important part...
If you see numbers under addresses, then DNS (Domain Name Services) is working and routing you to that server.
If you get addresses, post those back and see what other people get.
I got 67.225.154.41
You should get the same number if the DNS routing is correct.
If you don't get an address returned, try typing "ipconfig /flushdns" and then try the nslookup command again. flushdns will flush what is cached in your DNS resolver cache.
Did flushed DNS ,didn't work
I'll try the second variant , just don't want to screw up something , it's not the waters I'm trained to swim if you understand me
Thanks for helping
Indeed , N4420 it came by DHL this very morning , ordered it one week ago ,serviced,overhauled, from a guy in Germany.
Didn't even opened the package yet ....hope it's OK
Some OTARI machine in your avatar seems to me ?
