Vinyl stores in San Francisco
There is also a place on Green street, just a block up from Columbus that has boxes upon boxes of used records in the basement. Each disc will run you about $5. Wear your grungy clothes when you go cause you'll be moving boxes upon boxes of records as you flip through boxes upon boxes of records. THey also have used stereo gear at the upper level.
The store is named 102 Music at 513 Green St.
There is also a record shop a couple of blocks east of Amoeba on Haight St in SF. I think it's called "Recycled Records." They have a fair bit of rock and jazz vinyl.
