Thomas_AA
Well-Known Member
Well, my concern is to use the cartridges and stylii that gets most out of the grooves with minimal distortion and not spend a fortune. The Shure/JICO combination is good at that despite the higher than normal VTA. With respect to the Ortofon replicant there are quite a few pictures available where SRA and VTA have been measured. And regardless of the patent there is no one showing 20°. Effective VTA is more like 26-27° or more, see e.g.Ok, but what you're bothered about or not is not relevant and not an objective argument. Lots of people aren't bothered about many things at all, but this topic is about how to set the ideal VTA/SRA, how to measure it or it's consequences and potentially how it affects sound.
You're concluding that VTA number from that picture with the measurements, not from the patent. The patent states that the sra should be 90 deg:
and the vta of the cantilever should be ca. 20deg, so that is not really a set value. Their main claim is on the SRA. What VTA comes with that depends on how the tip is glued in.
Without actual de music files we'll never know. Besides which type of music files is always very very important in these. Inner grooves? outer grooves? amount of modulation?
I see it like IGD. Lots of people claim it doesn't exist or doesn't occur on their setup. That is a consequence of either not having music where IGD occurs, or they don't know what to listen for, or are just plain deaf. It's easy to make a setup sound beautiful. It's not so easy to make a setup sound beautiful everywhere on every record.
I'm mainly interested in where things start to sound noticeably worse.
You have that stylus. I don't. So you have to do the measurements whether or not VTF is set correctly on their recommendation. Lots of manufacturers are often dead wrong.
What's the dynamic compliance of that stylus? (without brush)
1.0-1.5 with a brush down is very very low. You'd expect a compliance of well over 35.
Whether or not more VTF brings you within your desired SRA range....depends on your static compliance.
However I doubt playing with the VTF would bring that stylus in your first example with that 8degree SRA error (according to the measurements) into the right ballpark.
The original v15IV is rated at 25mm/N, so that means adding 1g extra VTF (wich of course is a huge amount), only ads 0,25mm extra sagging of the stylus. That would result in a lowering of only 2 degrees on the VTA if the cantilever (tip to fulcrum distance) is 8mm long (pretty standard). Certainly not enough for the stylus from your first example.
And that's for 1g extra VTF. Adding half a gram or even less won't really do anything. Or that jico stylus must have an insane high static compliance of like 75mm/N or more, but that's unlikely.
But I assume you haven't done such calculations yet?
My original stylus for the V15VxMR had only one parameter that was better than the JICO and that was channel separation above 10 kHz due to its higher resonance frequency. But hollow beryllium cantilevers are not made today. Speaking of the original Shure MR stylus, below is a picture of stylus angle and effective VTA. Around 26° effective VTA, 6° more than the target 20°. What does that tell you for an old cartridge like the V15V? Cartridges vary between 20-30° effective VTA, as I mentioned earlier. There is no way to adjust VTA to 20° of all these by tonearm height - my initial statement was to adjust for SRA and leave VTA as is. If you have correct SRA and it would be possible to adjust 6-8° to get correct VTA, SRA would be off and you suffer from high frequency loss.
Regarding VTF there is of course no fix for the VTA - more for getting closer to the ideal SRA around 92 degrees. Compliance is 22 so that makes me wonder why JICO specifies so low VTF. It tracks 100 µm at 1.45 g brush down and has below -60 dB THD at 1 kHz, 3.54 cm/s peak. Which is top notch figures.
BTW, the music excerpt was from the final of Mahler's 2nd symphony, crammed in last track inner groove of the record, i.e. one of the most difficult passages to reproduce by vinyl.
And another edit;
as noted earlier there is an example on the site I linked to with music file with and without 12° VTA IMD distortion.Without actual de music files we'll never know.
