While that may be true for Yamaha receivers & some Yamaha amps, the meters of the MX-10000 & PC5002M show actual load.I suspect very few amps have any real load measurement as related to VU or LED power meters. That's not to say they don't employ thermal or clip (distortion) limits. I know for certain from reading the schematics and service manuals that vintage Yamaha receiver's VU meter readings are taken from the preamp stages and have little to do with actual power output since they'll register with no load or speakers selected.
While it is a good indication of the status of things, good or bad, they are simply an "estimate" of the power output, but they are SO COOL...![]()
Interstingly too, you could get just as much of an 'estimate' of the power by measuring the current and using the equality P=I²R, rather than the usual way of these meters of measuring voltage and scaling the meter according to P=V²/R. That DOES give a much better indication of the load on the amplifier, since lower speaker impedance directly results in more current. The downside is the meters read zero if no speakers are connected (which is in fact quite accurate; no speaker = no power)
My understanding is that analog volt meters are a lot smaller and significantly less expensive than ammeters (current meters).
The VU meters on my Yamaha amps move back and forth instantly to the slightest change in power. On very dynamic sources such as some classical music the movement can be dramatic.
If you want to talk about unusual meters take a look at my Wintec receiver. It has a row of LED's with left channel reading to the left and right to the right. The switch to the right controls the sensitivity of the meters. It's rather hypnotic.
Picture is from the web but just like mine.
