I am going to try to post pictures and narrate the process of making a walsh tweeter. This is neither difficult nor time consuming. First remove the speaker from the box and remove the flange from the speaker. 2. Check the speaker to see that it is good. 3. remove the silk dome 4. hot glue the 4 inch rod to the center of the magnet. I used stainless steel straws. Cut to length with a hacksaw. A pack of 4 from walmart is 3 bucks. 5. Glue the cone to the voice coil Clear Gorilla glue, be careful not to get too much glue on the driver.I use a 3 inch ring of foam pushed down the center to hold it in place while it dries You can carefully add glue to the base after it initially dries 6. fill the cone with poly fil. 7. cut a 3.5 inch ring of speaker grill foam from any source for the top, and glue in place. Procedure to make the cone. a. Get the pdf cutout from Jimbo. b. make a copy and cut it out. c. put a sheet of aluminum foil on the self adhesive laminating sheets from walmart. d. trace the cone onto the adhesive lamination sheets with the foil glued on it. e. cut it out with scissors. Tape the inside and outside to form a 1 inch hole at the bottom. f. paint it gold. I used gilding paint from Michaels. The laminated cone will have air pockets. I punch them with a needle and force the air out. You won't get them perfect. The paint covers that to some degree. If you figure a way to get them perfect please post it here.
All I can say is try it. I showed you how I made them. Make a set of stand alones and try 'em. Max investment is 60 bucks. You had mentioned you have a way to stamp or emboss the foil, did that work?I wouldn't play a tweeter "full range". You need a capacitor to protect it from the lower freqs, choosing the right crossover freq, a couple of octaves far from the Fs freq.
