I am still learning a lot about these Infinity's. I didn't realize that the Ren 90's were some of the best Infinity's out there. I thought the IRS Beta's, IRS Gamma's RS-1's, RS 2.5, RS 4.5 and the Quantum Source Lines were the better units of the Infinity drivers.
Well, can't personally compare them to an SM-150 (never heard one), but, while I suspect they would kick any of the SM series to the curb, I don't think they were close to the best Infinity. Maybe the "Best Infinity Under $5,000 post-1990" might be more accurate.
David
A pair just sold on eBay today. Keep a watch out for eBay and Audiogon, they come up for sale every few months. They are excellent speakers.
David
Well, they say a picture is worth 1000 words, but I guess I don't have 1000. I'm not an engineer so the crossover frequencies and bandpass for that particular speaker (mid-bass) are fine with me. So I'm not qualified to comment on the design--I'm not an engineer or speaker designer. But of course it's a rather simple formula for determining the resonant frequency of LC circuits. 1/6.28FC = 6.28FL where F is the frequency, C is capacitance and L is inductance.
Nope don't care who manufactured the parts. I don't know a good electrolytic cap mfgr from a bad one.
BUT, the construction, yes I have a serious problem with that. First of all I would like to see the components mounted on a PCB with traces rather than point-to-point wiring. The cables should be attached to post or else hard wired to a PCB via through holes. The caps should not be stacked on top of each other and held down with glue. They should all be mounted on a PCB and maybe secured with tied wraps. The leads coming off the inductors look hideous and they seem to be touching the case of the inductor. This looks at best like a build up in the research lab rather than a production run. I can't believe this came from the factory this way. This must of been somebodies home brew modification? Replacing parts would be difficult with this "rat's nest".
Actually I think the Ren 90's can lay claim to being the best monopole speaker Infinity ever made under $14,000 (ie: under the Epsilon). That would be the fairest way to rate them. That is a HUGE wrap for a speaker which had a starting list of $3700! They were and still are a phenominal value speaker when you consider they can be driven with a single high current amp happily & be placed in even modest size listening rooms with ease.
No offense intended, but the addition of "monopole" knocks out a huge percentage of what most people would consider Infinity's finest speakers - IRS, Beta, Gamma, RS-1, RS-IIB, RS-4.5, in fact virtually all their top of the line speakers prior to 1990.
If you want to redefine the question as to whether the Ren is the best "monopole" Infinity, then they very possibly might be better than anything except the Epsilon (I've never heard a Sigma or an Omega, so can't comment). But, in reference to the OP's question, while I think the Ren is a fine speaker, no way do I consider it Infinity's finest speaker.
David
Both the Sigma and the Omega out-perform the Ren 90...by a large margin. Also, technically, it's not monopole as the EMIM on the 90 does radiate out the back of the speaker, just attenuated through wool, egg crate foam and a final backing plate.
Actually, dipole speakers have certain advantages over monopole designs w/ regard to room interaction. The dipole radiating pattern has a null 90 degrees off axis which makes placement relative to side walls not as critical. As you state the back wall reflection does need to be dealt with and the speakers do need to be positioned somewhat out into the room. So far as I can tell that seems to be the preferred placement for monopole speakers as well. I suppose I do have some bias as my Infinities are Gammas and RS-IIs, but I find both relatively easy to place in my room.
Just my $0.02
J. Tucker
IRS Gamma
RS-II
ADS L710
You've said the Renaissance speakers weren't technically monopole, my understanding is that that vent only exists to vent pressure, not sound, which means is a true monopole...not dipole as you suggested. Infinity never described those speakers as monople to the best of my knowledge. Anyway, it's good to have a healthy debate and share our views![]()
The vent is a highly damped transmission line designed to reduce back pressure on the EMIM and eliminate rear wave reflections, so you are correct, it was not designed as a true dipole. Check out the section on the High Energy EMIMs on page 7 of the Renaissance Technical White Paper for a discussion on the theory behind it.
David
Actually, dipole speakers have certain advantages over monopole designs w/ regard to room interaction. The dipole radiating pattern has a null 90 degrees off axis which makes placement relative to side walls not as critical. As you state the back wall reflection does need to be dealt with and teh speakers do need to be positioned somewhat out into the room. So far as I can tell that seems to be the preferred placement for monopole speakers as well. I suppose I do have some bias as my Infinities are Gammas and RS-IIs, but I find both relatively easy to place in my room.
Just my $0.02
J. Tucker
IRS Gamma
RS-II
ADS L710
