Were Renaissance 90s the best Infinity?
BUT, the construction, yes I have a serious problem with that. First of all I would like to see the components mounted on a PCB with traces rather than point-to-point wiring. The cables should be attached to post or else hard wired to a PCB via through holes. The caps should not be stacked on top of each other and held down with glue. They should all be mounted on a PCB and maybe secured with tied wraps. The leads coming off the inductors look hideous and they seem to be touching the case of the inductor. This looks at best like a build up in the research lab rather than a production run. I can't believe this came from the factory this way. This must of been somebodies home brew modification? Replacing parts would be difficult with this "rat's nest".
I would agree that that isn't the prettiest crossover I've ever seen, by a long shot. A bit too crowded, for one thing, although minimizing distance between capacitors makes sense, they should be kept apart from the inductors.
I would always prefer point-to-point wiring in a crossover, and don't understand why you would want a circuit board there. Circuit boards are mostly for the benefit of the manufacturer, and possibly the repair(wo)man, but they bring no sonic benefits over point-to-point. If anything, they degrade the sound by adding additional connection points between conductors.
IRS is #1 rsI#2 just my 02
I am still learning a lot about these Infinity's. I didn't realize that the Ren 90's were some of the best Infinity's out there. I thought the IRS Beta's, IRS Gamma's RS-1's, RS 2.5, RS 4.5 and the Quantum Source Lines were the better units of the Infinity drivers.
Actually I think the Ren 90's can lay claim to being the best monopole speaker Infinity ever made under $14,000 (ie: under the Epsilon). That would be the fairest way to rate them.
I would agree. I'd rank nearly all of the IRS and the earlier RS series speakers as superior to any Renaissance model, including the 90s. But the 90s are the top of that line, which is the best of the "later" Infinities.
The BEST speakers Infinity ever made were the IRS Vs, without any question, period. Quite possibly the best speakers ever made, anywhere, by anyone, although some might dispute that.
I would consider most of the models you mentioned as having better sound than the 90's. I would also add the RS-IIb's to that list. I've heard the RS-IIb's and I think they sound better, mostly due to the IIb's having better bass and by their abillity to project more sound, but that's only my opinion.
The term "better" is subjective. Some people do not want a huge speaker. Some people prefer a speaker that projects less bass. Some people don't want to spend $10,000 for a pair of speakers, that would give them a small sound quality improvement over the 90's. For those types of people, the 90's would "better" fit their needs.
I dare say that some people would even consider the Bose 901's or some hard rocking CV's to be better!
OF course, if you interpret "better" to mean "most suitable for a given application", then at times some tiny speakers might be better. One assumes that "best" or "better" in the broader context here means "sound best when appropriately positioned in an appropriate environment"; that is, capable of producing the best sound, when properly set up.
No offense intended, but the addition of "monopole" knocks out a huge percentage of what most people would consider Infinity's finest speakers - IRS, Beta, Gamma, RS-1, RS-IIB, RS-4.5, in fact virtually all their top of the line speakers prior to 1990.
If you want to redefine the question as to whether the Ren is the best "monopole" Infinity, then they very possibly might be better than anything except the Epsilon (I've never heard a Sigma or an Omega, so can't comment). But, in reference to the OP's question, while I think the Ren is a fine speaker, no way do I consider it Infinity's finest speaker.
David
+1
To ask what their best "monopole" speaker is, is an entirely different question than to ask what their best speaker is. Most of the best Infinity speakers were dipole, for the simple reason that you can get a better, more realistic sound from a dipole than you can from a monopole, all else being equal.
None taken, and my addition of "monopole" was intentional and made in the full knowledge that this knocks out the above dipole models you referred to. Dipole speakers emit rear radiation as well as front, placing even greater importance on room acoustics. Honestly, how many people do you know have dedicated, acoustically tuned listening rooms who are able to get the most out of dipole speakers? Not too many in my experience, and for those of us who do not have an ideal listening room, or who have not employed room tuning devices, dipole speakers create more problems than any perceived benefits in the form of out of phase room reflections and other sonic ills. So for that reason, I feel Infinity's best monople designs deserve to be considered amongst Infinity's best speakers ever made..
So to summarise, I don't think, nor was I trying to imply that the Renaissance 90 is Infinity's finest speaker...it's just Infinity's finest speaker in my (and doubtless many other's) imperfect listening space
I'm not sure that a finely-tuned listening space is really all that critical to obtaining the sonic benefits of a dipole. A certain minimal room size is needed, because the speakers have to be positioned a few feet out in front of the rear wall, and still leave some distance between the speakers and the listener, so they are not appropriate in very small/short rooms. But as long as there is sufficient room length, dipoles need not be any pickier than monopoles. EXCEPT, perhaps, to the extent that they are capable of producing a significantly more realistic soundstage, and therefore you may find it easier to hear when things are not quite right. [i.e., they reveal more detail about location.]
Actually, dipole speakers have certain advantages over monopole designs w/ regard to room interaction. The dipole radiating pattern has a null 90 degrees off axis which makes placement relative to side walls not as critical. As you state the back wall reflection does need to be dealt with and teh speakers do need to be positioned somewhat out into the room. So far as I can tell that seems to be the preferred placement for monopole speakers as well. I suppose I do have some bias as my Infinities are Gammas and RS-IIs, but I find both relatively easy to place in my room.
Just my $0.02
J. Tucker
IRS Gamma
RS-II
ADS L710
Exactly what I was getting at above; dipoles aren't that difficult to place nor as demanding of room perfection, because they are less influenced by side wall reflections. Placement is just as critical with them as with monopoles, if you want the best sound, but the sweet spot for dipoles is usually significantly bigger than for monopoles, and they'll usually sound good over a larger area, even if the "complete magic" only kicks in for a portion of that area.
re: Renaissance speakers
There is quite a bit of deconstructing of comments about monopole/dipole Infinitys. The problem is that I think the thread is starting to feel a bit defensive with lines being drawn in the sand. Obviously there are Infinity fans who swear black and blue that their dipole speakers such as those mentioned above are the only speakers worthy of being regarded as amongst Infinity's best ever, when it seems apparent from comments that those who are bagging the Ren 90's don't like that kind of sound, whether or not those members have actually owned a pair themselves. Infinity spent years pushing the limits to build the Renaissance series of speakers. They built a radical trapezoidal-shaped cabinet designed to virtually eliminate diffraction altogether, they co-designed an entirely new and improved dual voice coil woofer with Charlie Watkins specially for that series, they designed and implemented 2 entirely new kapton drivers which they themselves said convincingly bettered all other Emit & Emim drivers that came before them, and for the first time designed and tuned their crossover by computer. The results were stunning as every owner of Ren 90's attests to (just read the extensive comments in Audioreview). Really, what I have found is that Infinity produced a number of speakers which all had their own character and group of fans. They're all bloody good, so why are we even bothering to forensically disect which is the "best" when at any given level of budget, within Infinity's extensive back-catalogue of speakers, there's probably a number of models which could be the best for that individual...
The important thing is what you think is the best Infinity! Aren't we lucky that we're spoilt with all that choice?
Just a thought, and I do have Ren 90s so I qualify as a critic, but would these speakers even have been built if Arnie was still around at the time. Are they tremendous speakers? No doubt, but are they better than my Kappa 9s, not always. In fact I generally prefer the Kappa 9s.
For what kind of music?
With the right amps The 9's are hard to beat!!:music:
I have listened to Tedrick's RS-IIb's and compared to my 9 Kappa's. To me the question of which is better depends on your preferences. Both had a similiar top-end, which is no surprise as both use EMITs. The EMIMs in the RS-IIb's were magical and clearly an improvement over the 9 Kappa's, but the 9 Kappa's have clearly better bass. Add an EMIM to the 9 Kappa and it would be amazing... wait that would make it almost an IRS Delta.
As a 9 owner I would agree whole heartily on your review above...They do however make components that can make the mids on the 9's sound much better...ie: EQ or a range expander:music:
I still think it would have been fun to hear an example of a Rennaisance 90 speaker utilizing a dual voice coil Watkins, even though the 90 is rated quite low in the low frequency department.
The Ren 90 DOES use a Watkins woofer, as does the 80. Or, did you just mean that you haven't heard it, and you think it would be fun to hear?
Inspiribomp, I thought Infinity quit the using dual voice design after the RS Series in 1986, ushering in the wonderful Kappa line. Do you know which other TOTL Infinity's after the RS series also utilize a Watkins dual voice coil, i.e. IRS/Sigma?? Thanks and no wonder the 90's can hit such lows:yes:
I think the Rens were one of the last to use a Watkins woofer, while some of the higher end models used servo-feedback (Gamma, Beta) to achieve their awesome lows.
Like I said, I believed the RS 2.5/4.5 were just about the last of the Infinity's to use the Watkins dual voice coil leaving about a five to six year( maybe longer?) gap until introduced back into the Rennaissance 80's and 90's. Why the big space in time with no Watkin's DVC:scratch2:.
Aaron I'd love to hear your 90's one day!
But I'm sure you are afraid Liz will want to runoff with me, so you'll never invite me up for listen :sigh:
Scott, you're welcome up here anytime. I think you'd really like the Rens. Let me know if you are able to make it up this way, or need a place to stay. Mi casa es su casa.
My ex-boss had a very nice pair of Kappa 9's. I listened to them on a few occasions. They are certainly very impressive and can throw out some serious sound. For me, I prefer the way the Renaissance 90's sound compared to the K9's. The 90's are more clear sounding in my opinion. I think the K9's are too heavy in the bass region and I actually like the sound of the K8's over the K9's. The K9's are definetely more versitile than the 90's, as the 90's are not well suited for home theater or dymamic music.
I would love to hear a pair of RS-II's one day. I really like the look of that speaker. I bet those three midrange cones can throw out some powerful sound.
I also want to report that I recently purchased a pair of new Beta 20's, as I am upgrading my HT from 5 channel to 7 channel. I know this board is basically composed of people that love pre-90's Infinities, but these new little Infinities sound very good for a small speaker. I A/B tested them in two channel mode against my Crescendo 3009's and my RS-4b's, and they did better than I expected. I have previously only heard the Beta 50's in that line and they sounded very good, so gave the 20's a try. For the price they are currently selling for, they are a great deal.
I just picked up a pair of Kappa 8's without Watkins DVC from craigslist for 50 dollars. Had to replace a rear firing EMIT and vaccum the cat hair off of the fronts and have them connected to a pair of Crown amps (bi-amped). I also in the same listening room have a Pair of QLS-2 with Watkins DVC paired up with a SAE 2400L amp, both of them hooked up to the same pre-amp a Sansui CA-2000 and I have to say the Kappa 8's sound just as good to me and slightly better in the low frequency region. I thought the Watkins should put the Kappa's to shame but I am not finding that to be the case.
I think they both sound great overall, and I have to say being dipole they sound very good almost any where I place them. I will say that prior to these I was using some Yamaha NS-1000m's and NS-500m's and although they were much more efficent and I loved the clear hi end and to me great bass, they sounded like speaker boxes putting out great sounds. Since I have been using these old infinity's with the dipole rear firing emit's and mid bass drivers they make the sound stage much larger and just fill the room with music and no matter where I am I don't lose that sweet spot that I had to be in with my Yamaha's
I hate to admit it but I have placed the Yamaha's in a spare room with moving blankets and don't know if I will use them again anytime soon. Maybe as a Home theater set up but they just don't sound as rich to me as the infinity models. Maybe placement is less as inportant with the Dipole Infinity's than with the Yamah's and I didn't experiment enought with placement for them to really sound their best but anytime I got up and walked to the edge of the rooms it sounded like I attennuated the high frequency's
The Sigma's are such a better speaker than the Rens, it's ridiculous to compare the two. I've had the chance to listen to each in the same room with same electronics (and I've owned 80's and 90's). The Sigma's are better in every way, smoother mids, better highs and nice tight, deep bass. The Ren's really struggle in the bass department.
My Revels actually sound more like the Sigma's than the Ren's did.:thmbsp:
I have not heard the Sigmas but I agree in principle with your comments. I have sim'd the crossover response of the Ren 90's and there is quite as 'S' shape through the EMIM - EMIT crossover region including a 2.5dB peak at 2.3kHz. The crossover has been computer designed but most of the values comply with the 5% standards to cut costs. Looking at the crossover schematic of the Sigma's it's easy to see that it's very fine tuned because the values are all 1 or 2% and do not comply with the 5% range.
The good news for Ren 90 owners is that there is some scope via component value mods to make the Rens sound essentially the same as the Sigmas above about 500Hz. I own Ren 90's and I have done some serious mods that have transformed them into giant killers. I'm about to upgrade the caps in the LF crossover and I'm expecting a big improvement in bass - quality and quantity. Having looked at the schematic it's easy to see that SQ will be heavily linked to the performance of 2 NPE electrolytic caps. My own Ren's don't sound as punchy and tight in the bass as they did from new so I'm looking forward to the results.
