With my crossovers, L1-5 all tested precisely to spec, so they were not replaced.
L-6 and above were all at least 20-30% under their specs, so they were replaced with new Erse (I believe Super Q) inductors which were individually unwound to match them to the exact spec.
If I recall, the DCR on the new Erse coils was a good match for the originals.
so you pulled the inductors out of the circuit (at least on one side) to do those measurements?
curious indeed that they each measure almost exactly 2/3 of the spec'd value. is each inductor labeled or are you getting the expected value from the position in the circuit compared to the handwritten schematic?
very strange. did you measure coils from both speakers or just one?
probably they will because hdjr808 found them to be smaller too.
i finished and the second speaker and the results are stunning.
infinity can`t unwound the coils.
they are fixed like EI transformers.
i believe the labels are wrong on purpose or not i don`t know.
besides the schematic is hand writen so propably the values was taken from the labels.
measuring 90`s in different rooms won`t give comparable results.
i wonder if timpani have the old coils to tell us the values.
anybody remember which coils are air core?
i didn`t touch the mid high crossover yet.
it would be a pretty big a coincidence to be a heating issue with that much consistency. that being said, i don't really have a better explanation. is there any way that Infinity could have partially unwound them by hand at the factory?
When I have some time next weekend I will test all of the old inductors - at the correct frequency of operation. This requires a function generator and an oscilloscope - along with several 2% capacitors of correct value.
This should answer all questions.
hello timpani.
long time no see
what do you meen by that?
an lcr meter gives wrong values?
