Gang-Twanger
Resident Wharfedaliophool
Hey everyone. Really happy to say I'm about to join the Wharfedale W90 club. Should be arriving tomorrow. Being delivered to my door from an awesome, amazing AKer.
They are these: http://www.audiokarma.org/forums/in...l-90-speakers-3-way-w-alnico-reds-499.684216/
They are going to be replacing my cornwalls which sound really good but my listening room is too small to get the best of them. I'll be listening to 60s and 70s classic rock, prog rock, jazz, classical and funk with some newer music like Dave Matthews Band and even some daft punk. I have a thorens TD-165 with a Shure M91ed and SAS stylus. Right now I have an HK730 but within the next couple of weeks my Scott 299b should be coming home after a full restoration.
If they sound 1/2 as good as Crestwood and Gang-Twanger's W90s i'll be thrilled!
Cheers!!!
Nice! You are going to love those. All-alnico, dual front ports, and dual sand-filled rear panels, just like my pair. Nice to see an AK'er get those. I was actually the one who got word to the seller that they should have SIX drivers instead of just two, so after a bit of time, he was able to get inside there and confirm it. Got some good shots of that original mid/tweeter panel that the drivers are connected to, and I copied the pics the moment I saw them, as I DIDN'T have any shots of the mid/tweeter panels in my pair.
With tubes and some precise attention to placement, those will make you a Wharfie fan for life. Put a lot of effort into the placement though (And I mean within a quarter-inch for the placement distances... With such a wide baffle, you really have to, as the magic lives within that quarter-inch of tolerance... Be precise, and you'll thank me later).
I have mine 2-3ft from the back wall, but they can go right up against it if need be, thanks to the front ports and dual sand panels. I would avoid putting them completely in the corners, as it screwed with the frequency response in my particular case. Not sure about your situation, but take it as a useful guide. And when you get them, look through the grillcloth and look where the mids and tweeters are. You want to put the W90's high enough so that the imaginary line that runs horizontally-across the dustcaps of the mids and tweets. THAT's the line you want to be right at eye-level.
And when you measure the distances, be sure to measure from BOTH sides of the baffle, as you want all four sides (two on each W90, the left and right verticle edges) to be the same distance from the centerpoint of your listening spot. That way you know they are pointed directly at you. Try and get fairly-close to the golden ratio for stereo speaker placement. Worked well for me.
And do not put the typical Dayton 250v polypropylene caps in those. They did more to hinder the sound than they did to help it, as far as I'm concerned. A fellow AK'er felt the same way about his alnico W70's with Solen poly caps. Sberger seems to have had good luck with the Jantzens he just put in a pair of alnico W60's, but he just got his oil caps delivered, so maybe wait to see how that turns out and how he ends up liking the oil caps. Your W90's should be from '62-'63. That's when that version was available. The earliest pair of W90's with ceramic woofers that I've seen is Crestwood23's pair, which were actually built the same month as my all-alnico ones, so I guestimated that they started mixing in ceramic woofers around that point, as changes/updates seemed to hit the US models in the fall (and the spring for British/European-marketed models).
Just put on. some Zappa just now. "Overnight Sensation" US LP ripped to hi-res FLAC.
