I was just going to use daytons but i will look those up. I removed one back and everything looks stock. The other back has newer screws with a square bit driver head so i am wondering what was done in there. When i get a bit i will find out.Excellent! If you decide to recap the cross, which is a good idea as by now these cap’s will have terrible ESR’s. I use Mundorf E-Cap’s these NPE’s have preserved the Wharfedale sound on my W35, and W45’s. The price is right.
And electrolytics are cheap!I recapped my W35’s the first time with Daytons. They were OK but when I rebuild my Polk Monitor 10B’s I used the Mundorf M-Cap’s once they broke in they never sounded so good. I was consulting with some Wharfedale guru’s and they advised me the W25, W35, W45, W60D/E, and W70D/E do best and their original sound is preserved by using NPE’s. I have the first 3 Wharfedales of this list. The original capacitors are a Hong Kong brand Minerva. All of them had very high ESR’s. They were basically resistors. When I installed the E-Caps on the W35’s which I purchased new in 1972 the sweet Wharfedale/English sound was there again. It was a no brainer on the W25’s, and W45’s
My ear tells me how loud to trun it up. Distortion doesnt sound good! My main speakers are bozak b300s and i have a set of leak sandwich from the 60s as well as polk m5s and 7s. The 7s are leaving. I loved them but they have been sold. My power sources are 2 gfa535s and the little onkyo reciever i use sometimes.Yes indeed. Even though I am very pleased with the results of the M-Cap’s on the 10B’s I spent $100 Dollars on the M-Cap’s. I spent Less than $15 Dollars on the E-Caps for the 3 Wharfedales. Of all of the speakers I own my Wharfedales are my favorites of those the W45’s are my sonic babies. I can, and have listened to them for hours at a time and they are not tiring to listen to. The only down side, if you can call it one, is these Wharfedales cannot handle the power most modern audio amp’s can put out. W25 = 10 - 35 Watts, W35 = 10 - 40 Watts, W45 = 10 - 45 Watts. W60D/E 15 - 60 Watts, W70D/E 15,- 75 Watts. My Yamaha puts out 95 Watts X 2. Less per channel 5.1. I am not going to take the chance damaging my Wharfedales.
I would be interested in hearing how the Bozak's sound compared to the Wharfedales when you get them recapped.My ear tells me how loud to trun it up. Distortion doesnt sound good! My main speakers are bozak b300s and i have a set of leak sandwich from the 60s as well as polk m5s and 7s. The 7s are leaving. I loved them but they have been sold. My power sources are 2 gfa535s and the little onkyo reciever i use sometimes.
Right now the bozaks have a big lead but that may change.I would be interested in hearing how the Bozak's sound compared to the Wharfedales when you get them recapped.
The w70ds are gonna sound great im sure. Right now the top is pretty dark so since i ordered the dayton caps already i will try them first. Also the bozaks have a cabinet twice the size which makes terrific low end and the top is handled be the 2 aluminum tweeters that i just love. The weakness of the b300s is that the mids are in the woofers till 2500hz. Plenty of mid and they sound great but i am betting the 8 and 5 in the w70ds will be better. If you ever wonder about the lowly b300s just know the sound huge. Then again, they are huge.One thing I found with the W45’s which had been in proper storage for several years is it took awhile for the 10” Wharfedale woofer to loosen up.
When the caps come i will. Gonna have to clip leads i think. I could just barely see in there with the leads being so short.You have a late model W70D. Just a guess I would say your W70D were made in 1968. Take a look at the back of the speaker cones the date of their manufacture is often written in pencil on them. What I rather like about the Wharfedale speaker is their die cast Zinc alloy frames ( aka pot metal). I didn’t appreciate this at first but Zinc is non-resonate metal it clunks, not rings, it is very ridged, and can be die cast with a very fine finish. Warfedale had local foundry's cast these frames. It is the ideal metal for speaker frames. But that industry is almost extinct aluminum having taken it’s place.
Those on my 1970 W45’s are all soldered, a minor PIA.When the caps come i will. Gonna have to clip leads i think. I could just barely see in there with the leads being so short.
Both tweeters are working right now. Really its amazing how well its all working. It just sounds like a recap is in order. I need to quit buying vintage speakers but i love em so much.Be sure to check out the tweeters. The purple fried egg tweeter were also used on the W60 and they are rather problematic. I believe the opening takes a 3.5” speaker there are several modern drop in replacements “Simply Speakers” has them.
