Wharfedale Owners Thread
The company in question is Speakerbits , in Melbourne , Australia . They are supposedly setting up a new website and unfortunately nothing happens when you try to open the portal. This has been an ongoing problem for about 6 months. What I can remember of that particular tweeter, certainly with the original versions starting in the late 1960,s is that the voice coil used aluminium wire and instead of using a flexible braid to connect the voice coil assembly to the terminals, the same v.c. wire was used as the connecting medium and this proved to be unreliable.
Thanks for adding information about the site. I couldn't find them, and now I see why. Didn't know they were down. Do you know if they used copper on their replacement diaphragms? Hope they aren't near any of the fires going on down under....
Good idea to read through entire thread as there's a lot of good info to be had. You can probably find a replacement tweeter on ePay as they show up from time to time. If all else fails, there's a company in Australia that sells replacement diaphragms to rebuild them.
hi ifv,
any definitive word on what glue to use? does this stuff i bought for foam surrounds look good? one poster mentioned multiple coats of nail polish and another mentions some kind of heavy super glue or something. i've got a ton of glues over here so it would be good to know what to use.
ALSO. i undid the three bolts at the face of the cabinet that holds the plastic piece at the tweeter. but one doesn't seem to want to pull fully out and another seems to have lost whatever it was originally screwing into and won't hold now.
any word anywhere on how to disassemble these? am i going in from the front with the three sets of FOUR of the flathead screws shown here?(!)
THANKS
I have been slowly working on a pair of w70e’s and am considering recapping the crossover that has no pots. I also picked up another pair of later model W70e’s made by The Radio People and the crossovers have pots for the mid and tweeter. The second set sound amazing as is but I’m sure the old caps have drifted a bit.
I have been reading a lot of other postings on the w70’s and have seen several recap projects from new electrolytic caps, Poly caps and a few using PIO Russian KBG caps. I want to also add larger gauge wiring but I feel I have over read on the subject or recapping with this or that. What I need is some straight forward information from those who have used poly caps and PIO, specifically what brand. I hear a lot of praise for Solen caps but worry the highs will be too bright. Here is a pic of one of the xover’s. Right now the original 6mfd, 25mfd and 3.3ohm resistor? Are sounding good, I wonder if recapping would make them better. I imagine a 25 uf PIO capacitor would be huge.
I have only done one recap job and that was on my Speakerlab super 7’s, I used electrolytic caps, I may switch them to poly caps and see if my bass improves.
047E315A-88B7-4183-ADEA-0571814C3902.jpeg 951F26D3-DFB2-43AA-B703-51432EC0E034.jpeg 73A216B7-1E0D-4082-A325-2622A90C651B.jpeg 60BA70FA-D34B-4941-8AE7-43E7CF1949C7.jpeg 19F765D1-4151-4FD8-8BFF-370586F32902.jpeg
My vote is for any good quality made film capacitor. Solens are an excellent choice. I used the Dayton Audio film caps in my W 60s that have been upgraded with Super 3 tweeters from W70s. They sound superb - not harsh in the slightest. I personally feel that PIO capacitors are overrated. I know others that would surely disagree with me on this.
Tone Miser, did you replace your purple tweeter with a super 3? I have one dead tweeter and am looking at a replacement until and original can be found or a new diaphragm can be sourced. Checked on the Dayton caps and the price is really good.
No - my 60s are the first gen that used the PST 4 tweeter. Those rolled off too low in my opinion (15,000 CPS ) and are more of a midrange driver. Because the ceramic Super 3 was rated at 1,000 to 20,000 CPS it is ideal for a 2 way cabinet. The ceramic Super 3 with the elongated mounting holes will ( just) fit the mounting studs for the original PST4.
Just go on Ebay and search Wharfedale tweeter. Then save that search using the ebay " save this search " tool with the heart icon. It will automatically email you when a new item has been listed. Be patient. They do show up from time to time. A bunch of jellyfish tweeters have listed and sold over the past few months
Got it, I’m still learning all I can on a lot of different vintage speakers. Thanks for the info. My tweeters are the smaller dome with the protective cover over them. I have a search saved for the tweeter, I may have found yet another set of the w70’s and maybe the w90’s, have to investigate that next week.
any advice on getting the back of these radio people 79’s off? put screws back in and get in there with some sacrificial wood and a claw hammer...?
I used a filed down paint can lid remover to fit in the top middle hole and pull the back off.
maybe i am missing something. elsewhere someone referred to front and back access wharfedales or something? meaning some you could only access from the back?
i mean on these the /front/ does not remove at all. but on the 60’s the fabric grill comes off.
starting to think i remember someone elsewhere saying to partially insert the screws and try to work the cover off i guess...
Ohm Ratings?
anyone know what i should be seeing for Ohm ratings at the terminals of a W60D markII or a radio people W70?
also, am i correct in thinking (bit of a noob here) that i can also check the individual drivers for Ohm values?
THANKS
Hey hot wheels, I have a pair of rosedale w70e’s and the backs come off and the woofer is mounded from the inside.They were manufactured 4/70. The radio people W70e’s were manufactured in Hong Kong in 6/70, the fronts come off but the backs are sealed. You can remove the cover for the rosedales the are held on by a small nail on the 4 corners. Also you have to check the ohms of each driver. I’m a noob also and don’t understand testing the crossover while it’s assembled. If your crossover has adjustment pots for the mid and tweeter they should be cleaned with deoxit or similar, a lot smarter people will add more info.
thanks. how do i clean the potentiometers exactly?
anything else to clean in here?
any ideas how i get the tweeter far enough out to inspect it? do i unsolder the wires for it at the crossover?
W70’s. anyone know if you want to take the tweeter off you remove the nuts holding the wood on or do you just take the screws out? or both?
Here is a picture of a crossover from my radio people W70e, the two silver pots are in the middle of the picture, each of them have a small hole, if you use contact cleaner or deoxit spray shoot a small burst into the hole on the side and work the switch knob fully side to side to clean the internals.
If you need to remove any of the drivers to test the ohms value, especially the tweeter, desolder them at the crossover, the tweeter has Aluminium leads and you don’t want to try and desolder the wires at the tweeter terminal. The jelly fish style tweeter you have is pretty fragile. There is really nothing else to clean or service other than replacing the capacitors and cleaning the pots.
