Wharfedale Owners Thread
I would just like to know the values of capacitors and coils.
here are mine. not sure what they are or if it helps.
If you need to remove any of the drivers to test the ohms value, especially the tweeter, desolder them at the crossover, the tweeter has Aluminium leads and you don’t want to try and desolder the wires at the tweeter terminal. The jelly fish style tweeter you have is pretty fragile. There is really nothing else to clean or service other than replacing the capacitors and cleaning the pots.
thanks man.
i was just reading that the pots have a hole you can shoot into. can i use this CRC spray? i have some Fader Lube on order as well for a stereo i have here.
what are the coils? are they just the working part of the potentiometer knobs? or what do i call those?
also. what do i call this thing between the drivers and the panel for the potentiometers? its glued to the front of the cabinet.
and do i unsolder here?
That looks like a bridge to me, you could unsolder them there. The coil is inside the potentiometer, some have wafers. You can use the CRC, just work the knobs back and forth after you spray the pots, maybe 20-30 times each.
THANKS vince. looks like that post is the W60 mark II’s i have been talking to you about (thanks and will do) and the grey boxes are the W70’s. hopefully i am not confusing things too much.
I think that's true of the early W70's models. Not the best design.
thanks gents. so what am i looking at here? or what are these two rectangular boxes exactly please? you are saying there is no crossover to segregate the signal i guess?
also, are the drivers worth anything? they look red which i had thought from reading was alnico (whatever that is...)?
/thanks/. remedial class here but there is a coil inside the metal disk potentiometers, ana a “voice coil” in the drivers themselves? or what do i call the coils next to the potentiometers and capacitors please?
The components of the red alnico are excellent. The problem is that the first W70 are apparently not crossing the 10 'and 12' woofer. That causes the frequencies of both woofers to mix. I think that in this box they wanted to do the same thing they achieved with the SFB3 model, but in a closed box.
so can i ask you for some advice and about the chronology or the model numbering. i have these W60D mark II’s i just got and i am in love with. the cabinetry and size and quality of these things are amazing. i have some magnepan mgIIa’s or something that are ribbon speakers i fixed. and some advent heritages. and now these radio people W70’s.
the W60’s are like made in the early 60’s?
i can’t understand the W70’s because they seem like they are not made with the same unbelievable quality as the W60’s. also they are much larger. we’re they supposed to be made later and are louder or something? seems almost like someone else made them.
also, can i ask you what these 70’s are worth or if i should keep them? or part them out or scavenge the drivers or what?!
are the 60’s the keepers? what about selling the advent heritages and the magnepans and just keeping the 60’s?
i’ve decided i love listening to horns. and really seems like i should just keep the 60’s? and the advents? trying to wrap my head around what i have i guess...
The first W60 models were introduced in the early 60's. The same for the W70 and W90 models.
The w60D and W70D models are later, despite being excellent speakers, I consider that the drivers used in the later versions of these models are of a lower quality. The red alnico are the best according to my humble opinion. Your W70 are EXCELLENT speakers, you should give them a chance. Look at this thread, it is very interesting and it could help you.
https://audiokarma.org/forums/index...fedale-w70s-biggles-dream-is-realized.638442/
THANKS man. will review that.
any way to get a handle on the 60’s compared to the 70’s? was the 70 considered an upgrade? the 60’s seem to me to be more beautiful speakers really.
would you keep both? i can start another thread on this i guess. my 70’s seem to have a less desirable crossover?
[QUOTE = "hotwheels22, post: 13409284, miembro: 182105"] GRACIAS hombre. lo revisaremos
¿Alguna forma de entender los años 60 en comparación con los años 70? ¿Fue considerado el 70 una actualización? los años 60 me parecen ser oradores más hermosos realmente.
¿te quedarías con ambos? Puedo comenzar otro hilo sobre esto, supongo. mis 70 parecen tener un crossover menos deseable? [/ QUOTE]
Both models, both the W60 and the W70 are from the same era (beginning of the 60s).
The W70 model does not mean that it corresponds to the 70s.
It is simply the name of the model in question.
The best models of that era are the W60, W70 and W90.
There are also more compact models such as the w40 and the w20.
The W90 is the largest model in this series.
They are all from the 60s.
If I compare the W70 versus the W60, the first is a larger box with 10 'and 12' woofers and super 3 tweeter.
Instead, the original W60 was a two-way model, with a 12 'woofer and a mid-tweeter pst4 or wna4.
The difference is simply a larger box with more tracks, the sound signature should be similar, the difference lies only in the volume of the box, number of tracks and crossover.
Your W60D speakers are a 3-way later model, it was the evolution of the original W60. I still think that the original 2-way version is better (personal taste).
I recommend you restore your W70 and make a new crossover, in the thread that I mentioned appears information about it.
Sorry for my English translated from Google, I'm Chilean.
Have you compared the alnico to the later models that use ferrite magnets? I would disagree that the earlier models are better. The speakers might be slightly more efficient, but the later models had much better crossovers and sealed acoustic suspension cabinets and are sonically superior in my opinion.
thanks for that! pst4 or wna4 are the different “mid tweeter” drivers in the 60’s series? is one the one with the plastic cage the better one? and the 70’s has the “super tweeter”?
Folks on the D&S thread do not seem to know so thought I would ask here. Any idea what models the floorstanders and bookshelves are? Are they part of a HT system as the other pieces also are Wharfedale, except for the receiver? The owner claims they are in great shape but he is selling them for an elderly friend and does not know the model. A 40 mile drive or else I would have gone for a listen already. But these need to be special as there are already too many speakers in the house. Any help or info would be appreciated. Thanks
These are similar to the D300 series but I couldn't find the exact model. I'd say they're pretty old judging from the style. probably mid to late 1990's model? They are nothing spectacular unless you need a 5.1 system.
Okay I will investigate those further. Probably will end up passing. Thanks for the quick reply.
That package according to the owner was just sold. So no need to respond. Thanks.
Yeah right.
I will try to be brief, I do not consider myself expert or anything, I just expose my humble opinion.
I currently own a pair of original two-way W60 with alnico magnet, and I also have a Rosedale pair (equivalent to a W70E).
First of all, it is worth saying that old alnico drivers have a superior manufacturing level and quality.
With regard to sound, the advantages of the W60 are very obvious:
- The first is the mid-high frequencies, the wna4 has a superior performance to the joint work of the mid-range and the purple tweeter, the sound reproduction is more accurate due to the absence of a cross at this frequency level, in addition wna4 tone is more natural. There are no offset problems nor do you need to mitigate gain differences through resistors or l-pad ... The Rosedale mid-range has a lower gain than the purple tweeter.
- The second, if I compare the woofers of both speakers, although the Rosedale woofer is 15 inches, I consider that the 12-inch red alnico woofer of the W60 has a remarkable performance, the first thing I rescue in addition to the alnico magnet is that has cloth surround, the Rosedale woofer has rubber surround, this cone is much harder to move. If I compare the bass responses of both boxes, I can say that the W60 woofer is faster, sounds more detailed, the sound is cleaner ... and most importantly, the resonance is nonexistent. On the other hand, the Rosedale bass is slow, sounds muddy, with much less nuance and the resonance level of the box is overwhelming.
That with respect to sound, although the Rosedale is a larger and three-way box, in practice the sand filled box and the simplest crossover give the W60 a clear advantage.
To conclude, the W60 is an extraordinary speaker and far superior to the Rosedale. It is more efficient, has a more precise sound due to the simplest crossover, has a more detailed bass, and the best thing is that you have a box without resonance. And finally, the naturalness of the sound that is achieved with the w60 is amazing (I'm not exaggerating). Read Gang-Twanger's threads, he was absolutely right with what he talked about these boxes.
[QUOTE = "hotwheels22, post: 13410900, miembro: 182105"] thanks for that! pst4 or wna4 are the different “mid tweeter” drivers in the 60’s series? is one the one with the plastic cage the better one? and the 70’s has the “super tweeter”? [/ QUOTE]
The wna4 and the pst4 are the same, the difference is that the pst4 has a polystyrene coating on the cone, if you remove the coating it will sound much better
