Wharfedale Owners Thread
Just a note of caution if you are looking at 70Es, they use the notorious purple dome tweeter that is prone to failure and somewhat unobtainable. I took these out of mine and modified new Visaton DT94's to drop into the original mounting holes (shown on page 55 of this thread). I have a pair of good purple dome tweeters in case I ever decide to part with these.
Mine are the D version, and have 4 speakers in them, 2 of which are not working. The top left two. The bottom right 2 work. No tweeter or mid
The good news is the drivers all look original. I'm guessing this is one of the later D's that rolled off the line as these all look like they have ferrite magnets. Possibly 1966/7 ? Just a guess. There are people on this site that are a lot better at deciphering the scribbles on the cone. In general, these don't look like they are in bad shape. There is no limit to how 'new' they can be made to look depending on what you want and how much you're willing to learn. My W70E's had missing/unglued veneer and dents in the back edge of the top, and a big black water ring on one of them. You would never know it to look at them now.
Don't assume they are dead until you unhook and test each driver for continuity. Those pots look very corroded; it's possible they are no good. Do you have a Multi-meter? If not, go to your local Lowes/Home Depot and pick up a cheap one for about $10. The only critical drivers you may need is the mid, and these are readily available on e-pay for about $26 each. The tweeters in these are probably the "purple jellyfish" which are known to go bad. Most people yank these out and replace them with new ones because they kind of sucked. Somewhere in this thread is a list of replacement models that people have used and the results they got. In general everyone says the new tweeters really make these shine. BTW if you don't have a soldering iron, pick up a starter kit while you're at the hardware store. It will only set you back about $12.
So I opened them up, only 2 drivers work out of the 4 it looks to have, and it looks like these were done in 89. They were also messed with. Not a happy camper right now to say the least. The mid and the tweeter are the ones that seem to not be working
OK, one more thing you aren't going to be happy about... whoever redid the crossovers used polarized capacitors. I can see a plus sign on the black ones, and the red one has a circular dent in the aluminum to indicate the positive connection side.
I pulled the tweeters and they are the jelly ones, and also pulled the mid on one of the speakers, it has broken wires and solder joints. I guess i will start with the mids, then order non polarized caps and look up how to redo them. Gonna have to look through here for replacement tweeters and recommendations.
The mids can probably be fixed. Broken tinsel wire is very common and it can easily be fixed, but you need to know how to use a soldering iron. Before you make any repairs or replace any drivers get a meter so you can verify if the part is beyond repair.
The 8" drivers are shot, one reads 0, and has no sound when going direct, and the other one has sparks coming from it when hooked up,and doesn't have a reading. The jellies are also shot. So as of now, I will need to 8" drivers, and 2 tweeter diaphrams, then the 4 pots, and new caps and resistors. The mid drivers and woofer drivers seem to be working.
Visaton DT94, are these 4 ohm, or 8 ohm version as my speakers are 6 ohm. And do they make these in 6 ohm? I just happen to have a pair of these from parts express that are 8 ohm.
My original tweeters have a DC resistance of 6 Ohms, but I believe their AC resistance is 8. I don't know much about the the purple tweeters you have, and I'm not sure that the DT94s are a good match. You should read through this thread and see what others have determined to be the right match. The DT94 may work, but I'm not sure what the efficiently of the 70Ds original tweeter is. When I chose them, I was looking at linearity, crossover frequency compatibility, and efficiency. On the W70Es they were indistinguishable from the originals.
The pots are L-pads, and are likely not available as per many owners before you. They work different from a potentiometer.
BEWARE the white dust on those pots. ITS TOXIC (Cadmium oxide) Wear gloves and a mask when working with them.
I saved mine by unsoldering them and soaking in 99% isopropanol and a light tidy with a toothbrush.
After flushing them and draining several times, gently work them thru their range to help loosen internal debris.
Spray deoxit into them to further clean the contacts. Work them thru their range with the deoxit.
Finish with some deoxit oil inside and out.
Cheers
So I'm guessing the Super 3's are a better fit then?
So as I am awaiting parts on the W70-D's I also have a pair of W60's.I would like to recap them, but wanted to see what people are recommending on them. I am not really a fan of these at all,but would at least like to upgrade the cap to see if there's going to be a difference in sound quality. What I'm seeing on the caps in the speakers are they are Hunts 12uf 150v d-c metallised paper. I am totally new to doing anything with cap work, so I don't understand anything about them.
I don't know much about the W60s so I can't tell if those are original or even if they are the correct value. Like I said before, spend some time reading through this entire thread and you will probably find the information you're looking for. If these are the early ported 2 way version, I would set them up with the proper crossover but would pass them on as they were not stellar performers.
I'm at that point already of passing them on. 80's Japanese brands and the old Fisher 3 ways sound nicer than these
So, I started trying to clean the L-Pads on the speakers and started with the treble pads, this was the 1st one I opened. I did wind up however getting it to work in one spot for now, just so I can see how these sound. Did the second treble one on the other speaker. These are definitely a full restoration project. I got the purple tweets in, and installed them,as well as the 8" mids. They don't sound bad, but they don't sound great either,and the imaging is not all that great yet. I'm sure it will get better once I fix the pad issue and maybe redo the crossovers. Are there any comparable pads anyone has had good luck with? The W60's I have have JBL pads on them. Night and day with the speakers even with the 70's needing a rehab. Once I get the innards done, I am going to reveneer these .
One side of my W60 echoes too much sometimes so I suspected an L-pad because it still has the original one. In the case, it is written 50ohms. I looked at inside and it looked clean but the resistance of each is different. One is 50ohms but the other is 500ohms. Is it designed in this way? In the picture, the copper like coil is 50ohms and silver like coil is 500ohms.
Should I look at different place to find the source of too much echoing? It sounds like base is too strong that the speaker can't handle. It's not too loud but it vibrates too much like echoing.
It should be 50 Ohms. Someone probably replaced the original.
So I wound up getting these for a trade and had to replace the 2 purple jellies. Used the ones I bought to redo the other ones I have here. So these are a complete pair,L-Pads seem to be working fine, gave them a fresh spray. Going to still try to refinish the other pair,but at least I can try these out. They are on the floor now, just wanted to see how they'd sound off the floor. Really nice looking speakers. Is there anything to do on the cloth surrounds for the woofers for preventative maintenance? They are alnico, but it looks like the other drivers are ceramic.
