Wharfedale Owners Thread
nice looking, shadco
those look like early w60s, gangtwanger can tell you for sure
probably have cloth surrounds, so no refoaming needed. you can tell if the back comes off as there will be screws all around the back. with my early w70s the baffle is pretty securely attached to the cabinet so would be very hard to change out the grill cloth. on the later w60s (i have w60e) the grill is attached with magnets and comes off easily.
wanted to chip in... had a devil of time trying to get the grill off my W60 cabs which seems glues in to a wood frame. Just living with the old discoloured torn cloth for now until I gigure out another way. Wondered about cutting around the frame on the outside and new cloth mounted from front?? Still sound nice but a bit tired.
Welcome to AK! This is a heck of a thread to do a first post on. Read through this whole thread and you'll learn how to get to the front baffle to change the grill cloth. It ain't easy on an early W60. From what I understand, you have to take the back off, remove the stuffing, remove the glued on wedges that hold the front baffle in place, then knock the front baffle out from the front. Oh, and you probably need to remove all the speakers before you do any of this.
Hi, i wont go on and on about my W70's (no "letter" 1960, ported, alincos and super 3's), you can see my rejuvenation of my pair in the Speaker thread.
What i do have to say is...... wow. I really am shocked how they sound. Im using an Optimus sa-155 1.8wpc amp for now and they are in my garage. I have them 2.5ft apart and chair is 7ft away playing at about 60-65db. I know youve all heard it before but i am actually hearing things i havnt with my other speakers. This hobby is so hard! Its not like you can run over to your buddies set up to compare. Or, with normal life, keep switching things consistently for any reasonable listening.
But it is fun!
Mike
I hooked the w70's to a Sherwood S-7100a. Volume at about 11 oclock, loudness off, tones at 0, im getting about 70db at my chair. I started with the super 3s 100% and have been slowly backing them down. They are really clear!
Hello, I am picking up a pair of Wharfedale W60, and W70 tomorrow and wanted to see what I should be looking for on these and what I should do when I get them home. I have 4 different power options for the 2 pair, a MAC1700, Yamaha CR-1040, a pair of Maggie mono block amps at 22 watts, and a Class A SET amp strapped in triode mode pushing 4.5 WPC. I have been reading how the 70's are comparable to Bozaks, and may be picking up a pair of the Bozak 302 A again. Unless these sound as good as some comments I've been reading. The 60's are the 2 way,and I don't know if they redid the caps or not,but they did say they were redone. The 70's are unmolested and will need some work to the cabinets, and are the plain squared cabinets without any type of molding on them.Any info is appreciated.
Hello and welcome to the club. My advice for power is don't go over 25 watts. That's all your going to need anyway. If the W60/70 don't have any letter then they are the early versions. Read through @Darby Crash threads as he just completed a full restoration on a pair of W70s. You will want to make sure all components are original and check the tweeter surround to make sure it's OK.
I think the 70's are the "D" version
Hope this isn't too late.. If you can't open them, up cabinet condition, model numbers and having the correct drivers would be things to look for.
  • Small amounts of water damage can be repaired and these can be re-veneered, but you'll have to gauge by what you're willing to do.
  • From the front, if you can remove the speaker fabric/grilles, take a look at the drivers to make sure they are originals. If you look at photos of the various W60s and W70s, you'll get an idea which ones have what speaker configurations, are ported, etc.
  • The earliest models usually have all-alnico drivers (alnico drivers will have a red band around the magnet and non will have a black band) and are ported and the later models a mixture or no alnicos.
  • I think the sweet spot is the D series Mark IIs. E series don't have the sand filled backs. The other models are good too, but I think the D Mark IIs are the most refined. E may be better, but I think not having the sand filled backs makes them more resonant.
  • For the woofers, check that the fabric surrounds are intact, as these can't easily be replaced as can foam surrounds, however are super durable.
  • If you can play them, check by putting your ear up to the drivers that all the tweeters, mids and woofers are working. You may have to tweak the little adjustment knobs on the back to hear the tweeters as the pots may need a good cleaning. Sometimes pulling them out slightly, when turning to max, and moving back and forth cleans them enough to let you hear the tweeters better.
  • The little plate on the back will tell you the model numbers, if they are present and also, the serial #s. If you're lucky, these will be a few #s apart.
  • You can also check the screws on the back (or front depending on model) for scratches to see if they've ever been opened up.
I can speak to that. I don't find them resonant as the backs are glued in place and use high density material. The W70Es have the most sophisticated cross over of all the W series and is the only model that sports a 15 inch woofer that goes down to 20Hz. I love the sound of these, but they are not as efficient as the D's and have a noticeable hump at around 37Hz. I usually run the bass controls pretty much flat. I grew up with KLH model 5s and I prefer the sound of the W70Es as they, like there predecessors, excel reproducing piano, string bass, jazz etc..
For when you get them home, I've only rehabbed a few pair of speakers, but here's my usual routine.
  • Give them a listen again and check for any drivers that don't sound "right. If you're happy, you have the option to leave them as is, but I like to open them up and give the components a once over.
  • For any drivers that are not working or somehow off, check them with an ohm meter, so that you can identify if the problem might be the driver or something else (crossover, adjustment pots, wiring). I'm a 'while I'm in there' type of guy, so usually remove all of them and check continuity. This just gives my OCD peace of mind that lefts/rights match and are in spec. Usually give em a bit of a shake to see if there's any conductive debris in the coils.
  • Give everything a good clean but beware there's sometimes a cadmium oxide (yellow dust) that you do not want to touch or breathe in. I'd recommend researching appropriate precautions and hopefully some members will chime in.
  • Check the surround material for mids/highs as appropriate. Purple dome (including plastic covered) don't have foam and I think most woofers are fabric, which are usually pretty durable, but if compromised, not as easy as replacing foam, rubber, paper surrounds with respect to parts availability.
  • Check the wiring/connectors and replace as necessary.I like to remove and clean the connectors on the speakers wiring with a small, fine wire brush. Just make sure the dust doesn't get into anywhere like the spiders, etc.
  • Clean the adjustment pots with DeoxIT, CRC or your favorite cleaner. You can check this with an ohm meter also and if they don't work, you can bypass or replace the pot. I like to bypass them, as I have other means on controlling this and prefer to do it 'centrally'.
  • Check the capacitors and resistors on the crossover and replace as necessary. Some folks (including myself) just replace them as a matter of course, if they are paper/electrolytic. Some models have cool British military spec oil filled caps. I've found that new caps do need a break in but this is an item of much debate!
  • Put em back together and give em a good listen to make sure all is well.
As a note, I'm a hobbyist and not a tech, so others may have better advice.
Good to know!
I should have qualified that I've not owned or extensively listened to the Es. There's a pair available locally that I'd dismissed previously and will have to give them a look.
Good to know!
Just a note of caution if you are looking at 70Es, they use the notorious purple dome tweeter that is prone to failure and somewhat unobtainable. I took these out of mine and modified new Visaton DT94's to drop into the original mounting holes (shown on page 55 of this thread). I have a pair of good purple dome tweeters in case I ever decide to part with these.
Well the 70's are the "D" version, but in need of a lot of work on the exterior alone. They smell terribly of mold, and I haven't opened them up yet. These were an Ebay purchase and pick up on a porch deal. There's also some veneer peeling up from the top and bottom of one speaker which the seller didn't speak of in the listing. Have them hooked up right now to play a little, then will open them up and deoxit the L-pads and contact points.
For me to check the drivers, can the front be popped off to get behind the grills, or do I have to go in from inside and remove the angled shims holding things in? I'm hoping I didn't bite off more than I can chew on these. Sound so far is ehhh, but I know they need to be cleaned up and recapped. It sounds like all drivers work so far.
If memory serves, the fronts screens are attached to the face with velcro, and if you need to get inside, should be the screws on the back, with an inset wood panel. I recall these screws being long flathead screws and having the turn the boxes on their backs to coax the panels out. I immediately replaced the screws with torx heads of the same size.
You might let em 'run' for a few hours. I've had a few vintage speakers that needed to be exercised for a good while before they sounded listenable. I recall the W60Ds IIs I had with the green woofer surrounds being that way and per a forum members advice, I ran them face down for a good while and they came back to life. I wish I never sold those, as they were a great jazz, vocals, piano speaker.
So I opened them up, only 2 drivers work out of the 4 it looks to have, and it looks like these were done in 89. They were also messed with. Not a happy camper right now to say the least. The mid and the tweeter are the ones that seem to not be working. Deoxited the pots as well.
20201130_172534.jpg 20201130_172537.jpg 20201130_172552.jpg 20201130_183634.jpg 20201130_183645.jpg 20201130_183647.jpg 20201130_183649.jpg 20201130_183651.jpg 20201130_183707.jpg 20201130_183717.jpg
