Wharfedale Owners Thread
^^ Thank you!
Was reading that link, its perfect. Thanks
Im gonna try to do felt surounds
Edit:
I tested both tweeters and got 6.5 ohms on both, i hope that means the VC's are good.
There are so many threads on these speakers i dont want to clog this owners thread so im posting in the speaker thread.
Thanks for your help
New to this thread and also new to Wharfedale speakers ..just purchased a set of TSR 112 behemoths from a fellow in Kamloops ..a bit of sanding and oil brought them back to stunning condition. Just wondering if anyone has any info on theses speakers ..there does not seem to be much on the webinar terms if specs.
Also a XO schematic would be wonderful.
Thanks in advance
Andrew
Also new here but not new to Wharfedale, I have a set of Lasers standing here but I cannot find anything on them... They're Laser 65 but there's literally no info on them. Anyways, one woofer seems to be on its end of life and I'm looking for new speakers, would the Laser 130 be a good choice? They're in a second hand listing near me for $40, reasonable price?
I see a pair of W70 are available on Ebay. They have grills and style of badge just like my W90 and mine have sand filled backs and are from 1960. So first in the series
They are in Sacremento. I am in Toronto, and have no affiliation to seller. Just an FYI to anyone wanting some nice W70.
https://www.ebay.com/itm/174304730298
Thank you.
Well tested them this morn. 1 everything works. At first no tweeter but turning the pot back and forth and it popped on. #2, tweeter is shot ☹
View attachment 1896766 View attachment 1896767 View attachment 1896769
Does the 12/60 on the woofer mean Dec 1960?
Yes, I think so.
In my experience with Rosedales from the 70s and W90 from 1960, the chalk writing on the back of the cones does match up with the time a given model was made.
My guess is the factory made a unit (woofer, mid-range or tweeter) and dated it for inventory and production control. One will see varying dates in a finished product with multiple elements but they still tend to a narrow time frame of a few months apart.
So Darby, you have an nice antique pair of December 1960 ish Warfies .
P.S. It should be do-able to fix those super tweeters surrounds.
Cheers.
Ive spent at least $20 and a month trying to buy felt. It seems way to thick. The last piece i got is 2.5mm. Any help on the felt buying department would be great.
2.5 mm is .1 inch, less than 1/8th of an inch. According to info in this thread, the tweeters don't have that much excursion so your 2.5 mm wool felt should work.
Does anyone know when the final W series Wharfedale's were made. That would be the W25-35-45, 60E, 70E, and the W80A Variflex. I have never been able to pin it down. I purchased my W35's in 1972, I know this final series were introduced very late in 1969. The marque in the early 1970's was not really marketed across the US. plus they didn't advertise much. It was after the final W's that Wharfedale started into a period of questionable quality.
I see nobody else has any knowledge of this either. I am guessing late 1974. It sure does not help that Wharfedale was never interested in saving it's records.
Going to put the W25's in service, and rotate out the W35's. I need to recap the W25's. They have the original 6 MF 50VDC IDE NPE cap's. I have decided to go with film cap's this time. Going to use Gen 1 Sonicap's. Was going to use Axeon Truecaps. They are individually cheaper but the Postage from Canada is a killer. I toyed with the idea of using the Mundorf M-Cap what I need is about the same price The problem is their enormous size. As I have said elsewhere the W25's were my AR speaker killer. My Original W25's back around 1980 blew my AR-7's out of the water. .
It seems, Transmaster, that you could very well be right. Unfortunately, Gang-Twanger is no longer with us; he was last seen in AK Oct.1, 2016. If anyone could have answered your question, he could.
I have the book, A Pair of Wharfedales (ISBN 978-1-906715-14-4) written by David Briggs, whose grandfather was Gilbert Briggs' first cousin. In that book, there is but one mention of the well known W series. It's a copy of an ad dating to 1964-5. It advertises on p.209 the new Anchromatic Speaker Systems that evolved from the Wharfedale 60, later to be renamed the W60. The Wharfedale 60 began its life in 1960, hence the name. By 1963, there was released the W40, W60, W70 and the W90. The only description of these systems is the amount of speakers in each and a list of the components used in all the units but little to no info as to which speakers were used in each cabinet system.
At the end of the book is an appendix 4: Wharfedale Products 1932-1978, of which there are 256. It includes early raw speakers, kits, transformers, trannsformer type attenuation pads, crossovers, some electronics including amplifiers, receivers and tape recorders. Here is a list of Cabinet Systems from 1959 to 1980.
W2, W3, W4 1959-1968 All used a WLS/12 woofer in an AF12 reflex enclosure. The 12" unit had a foam surround (annulus). Also used in some of these cabinets was the recent Co-Axial 12. The W2 later became the Dovetail (1965). The W2 was 2.3ft^3 and used a modified Super 5. Xover at 1khz.
The W3 was 2.7ft^3 and used a Special 5" and a Super 3. Xover at 1khz & 5khz. The W4 was 5.8ft^3 and used two 5" units and a Super 3. Xover at 400hz & 5khz. All had level controls. There was no mention of the difference(s), if any other than the name, among the 5 inch units. Possibly, the one used in the W2 had an aluminum voice coil since there was no tweeter but that's just my S.W.A.G. (Scientific Wild Ass Guess)
In this list, the dates most likely pertain to the dates of sale, not necessarily the actual dates of inception. This theory was derived from the dates on the last systems beginning with the E50 & E70. The dates 79, 80 & 81 clash with the appendix name which ends at '78.
Airdale, 61-69; Slimline 2, 62-569; Bookshelf 2, 63-65; Linton, 65-67; Dalesman, 65-67; Teesdale, 66-68; Super Linton, 67-72; Denton, 67-71; Rosedale, 69-73; Dovetail III, 69-71; Triton, 70-71; Aston, 70-71; Linton 2, 71-75; Triton 3, 71-74; Melton 2, 71-74; Dovetail 3, 71-75; Denton 1, 74-76; Kingsdale 3, 74-75; Denton 2XP, 75-78; Linton 3XP, 75-78; Glendale 3XP, 75-78; Dovetail SP, 75-77; Airdale SP, 75-77; Chevin XP, 75-78; E50 & E70, 77-81; Dovetail SP2, 77-79; Teersdale SP2, 77-80; Shevin, Denton, Shelton, Linton, Glendale all suffixed with XP2 and dated 78-80.
Robert
I have The book A Pair of Wharfedale's as well. There is brief mention of "the American Wharfedale's, and I mean brief. There is no mention of what they were. I think they are the W25, W35, W45, W60E, W70E, and The W80A Veriflex. The cabinets were manufactured in Missouri. The crossovers and drivers came from the UK. The Speakers were finally assembled in New York. I have no solid information to back this up. The W90 might have been American assembled as well. This is not forgetting The Hong Kong Radio People Ltd units.
Listening to my 50 year old W45's. They have been completely refurbished. The crossovers rebuild with Mundorf E-Cap NPE's with Gen II Sonicap bypass cap's. I also rewired the speakers Wharfedales of this vintage have soldered internal speaker connections, Everything is now soldered with Cardas Quad Eutectic solder. I needed to put longer wires to help ease future removal of the speakers. The sound these speakers now have is utterly astonishing.
An interesting aside. My Etymōtic ER3SE earphones sound very much like the W45's.
Wondering if you fine folks might be able to help me out. I came into a beautiful, custom teak stereo console with a nice Fisher KX200 & KM60 duo running the show. It came alongside 2 speakers with a seemingly well chosen set of Wharfedale drivers in it.
The Super 3 tweeter is the only one I can 100% identify (glad there was a sticker on those), but I can't seem to find a conclusive answer on the other 2 drivers.
After extensive google image searching, I believe the woofer is a 12 RS/DD, but am only 90% sure. The midrange 8" (or 10", but I'm pretty sure 8") is a bit of a mystery, I've seen a few with the red square (alnico?) magnets on the back, but can't find any that have 3 braces holding the cone, not 4. Here's a brochure I found for kit speakers if it's helpful: http://www.troelsgravesen.dk/Wharfedale_cat_files/Wharf_kits.pdf
One other thing to note, both drivers have a dark grey/brown inner cone and a cream outer cone (the 12" has a smaller section than the 8")- I tried to adjust the colors on a phone photo, maybe it helps, just what I can see with a flashlight through the speaker grilles which don't come off. I read somewhere they used Flexiprene on some drivers, but didn't see any others while I was searching that had this dual color scheme on the cone.
If anyone has any thoughts, would be greatly appreciated - cheers!
UPDATE: Went back in and couldn't find much in the way of markings, also doesn't look like there's a crossover, but got a lit up shot of the dates on there and it seems like they have felt or cloth surrounds. They're either '60 or '64.
UPDATE 2: They're definitely '64 as the reel to reel that came with it (Tandberg 74B) was introduced in '64.
My guess is that the speakers you have are the Wharfedale 10'' Bronze/FSB which appears to have had the original foam surround replaced with grey flannel cloth and a Wharfedale12 RS that has had the cloth roll surround also replaced with grey flannel material.
