The way into this model is from the front. Use a thin paring knife, and slide it down between the cloth and the wood trim about 1/4 to 1/8 of an inch then slowly turn the knife so the sharp edge of the blade catches the cloth until the grill starts to lift. These sealed back models had Velcro or magnets to hold them in place. After the grill cloth is off, lay the speaker down on a bed and take the screws out of the woofer. Now you want to gently roll the cabinet over until the woofer starts to tip out - make sure to hold the frame and don't put your finger through the cone. Once you can grab the frame the rest is easy. Just remove the wires (mark the frame so you can put it back the same way it came apart). Now that you have the woofer removed, take out the damping material (take a picture to make sure you get it back in the same way).
You should now see the crossover. This model uses 4 and 16 uF 50v non polarity caps. I purchased mine from parts express. You won't find a 16uF so you'll have to make one. In my case, I just bought a bunch of 4s and soldered them in parallel to make a 16. You will find a schematic of this crossover
here. Hope this was helpful.
